Hour meter operation??
/ Hour meter operation?? #21
Back in the early 90s, I rented a Kubota with a mechanical fuel cutoff lever. I discovered early on that the hour meter would stop if I turned off the key, but the engine would keep going. If I had wanted to run the tractor for more than 8 hours per day, all I had to do was shut off the key and keep going.
/ Hour meter operation?? #22
Lets have both, then you will know if the hours where put on with lots of idling or lots of wide open throttle.
On the 399 if you shut the key off it doesn't count any hours. :eek:
When did we get the new smilies? I like 'em. :thumbsup:
I've seen quite a few units with both mechanicalproof meters and electrical clocks. some cat equipment has a clock that runs whenever the battery key is on, whether or not the main ignition key is on..
soundguy
/ Hour meter operation?? #23
mechanical oil pressure gauge or idiot lamp? if mechanical gauge you'd be good to go.. if lamp.. many are key on only..
soundguy
/ Hour meter operation?? #24
One time that I happened to notice last summer I ran the B3030 almost exactly five hours but mostly about 1800RPM running the BH and rolled up a bit less than 3 hours on the meter. It does seem a lot closer to clock time when I am mowing or some other job running PTO speed. I'll have to check it when I have a PTO RPM job and see how close it is.
/ Hour meter operation?? #25
Not that this is tractor related but most every small airplane I have flow has had a hour meter that comes on as soon as the master electrical switch is turned on. They also have tach hour meters that accumulate 1 hour at XXXX rpm. Guess how they charge you when you rent them? They do the maintenance by the tach meter.
The jet and turbo prop airplanes use a weight off wheels method. So you could sit on the ground with the engines running for eternity and not rack up a single hour but as soon as the weight comes off the wheels it starts counting.
Chris
/ Hour meter operation?? #27
Ah! This thread answers my earlier question about my B8200 tach- it is a tach that reads one hour for one hour at rated RPM, which is suppose is the 540 PTO speed of 2600 engine RPM. I can see how engine speed would relevant to engine hours, but long idle periods would require survice, too.
/ Hour meter operation?? #28
This is why I would never buy a contractors truck, old police car, fire truck, ect. Too much idling that is not accounted for.
Chris
/ Hour meter operation?? #29
There is one more wrinkle to this (not to beat a dead horse).
My first tractors used cable-driven hour meters (Kubota), so even
turning off the starter switch would allow hours to add up if the engine
was running (no shut-off solenoid).
The JD4300 I am rebuilding had an electronic hour meter that had failed,
and the instr cluster got its signal from the alternator. This implied that the
hour meter could be engine speed related OR just a real hour indicator. It
would be easy to make the JD hour meter count pulses, like the electronic
tach does, to read "hours" like the old cable-driven meters did. I don't
know what JD did there as my factory meter was DOA. I added a
"proof meter" that works off the battery signal thru the starter switch.
As SOUNDGUY indicated, the owner's manual should tell you how the hour
meters work, but none of mine do.
I don't know how often these LCD electronic meters fail, but there sure
is valuable info lost if they do! This applies to your road vehicle too. I
don't know anyone who has had a LCD odometer fail (yet).
/ Hour meter operation?? #30
Some fire engines have odometer and hour meter. On scene, you may be running while scene lights and stuff are on. The midship pump runs with the tranny in gear; I do not remember if it shows as miles.
One of our engines has extra hours on it; almost 10. Does not seem like much, but that was one incident. Engine/Medic responded to medic call; person had been shot. The shooter was still thee, and threatened. Medic unit was able to drive away; logistics required abandoning the engine for crew safety so they literally ran from the scene. Was hours before they could go back in. Person was holed up for a while, shot Deputies, before all was done(person finally shot themself). Bad call to be on... Still, would be on the hour meter.
And, it would be FUN to have an old late 50's American LaFrance :D Hours or not :D
Chris
/ Hour meter operation?? #32
There's just no telling how many vehicles are like that. I know the Matco Tool trucks have both and I've no doubt it's true of the Snap-On, MAC, Cornwell and other tool trucks. You know those are air-conditioned rolling showrooms and the engines run all day. So the scheduled maintenance; i.e., oil changes, are based on the hour meter rather than the odometer.
And while I'm not absolutely sure, I believe the hour meter is a clock rather than RPM based.
/ Hour meter operation?? #33
The niftiest setup I have seen for determining when service is due was on the last big truck I owned. It had a Cummins N-14 engine with electronic controls and on the dash was an LCD display that (among other things) showed fuel mileage and advised when service was due based on gallons of fuel burned since the last service.
/ Hour meter operation?? #34
Should see one or two tonight; One is the charter rep for our Boy Scout Troop(although he lateraled from another dept just after that incident).
If you see any of the EDSO Deputies, tell them hi and to be safe so that after each shift, they can go home to their familes :thumbsup:!!! KC
Thanks for all of the posts and knowledge.
In summary it appears that there are several ways "hours" can and are recorded even on similar equipment. Often an hour does not mean 60 clock minutes. In some applications it does.
That information is what was being sought so there is much appreciation for the willingness of folks to share their experiences by posting here on TBN.
/ Hour meter operation?? #36
I've got a 2011 JD 2720. It registers .7hours, operating for 1hr at 1600 rpm. It measures .9 hour, operating for 1hr at 1800 rpm.
Those are the only two measurements I have so far. I'll try mowing at 2600 next time.
/ Hour meter operation?? #37
This is an old thread and I may have missed it, but I don't believe the DK35 SE was reported. It is different from the older DK35 reported near the start of this thread.
The 2011 DK35 SE (and 40, 45, 50) record the engine run time ignoring the rpm's. It determines the engine is running by determining that the alternator is charging.
JOHN DEERE 310 - 16' DISC HARROW (A64276)
JOHN DEERE 310 -...
2014 Mercedes Benz CLA 250 Sedan (A61574)
2014 Mercedes Benz...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
