hot water heater install
   / hot water heater install #1
tbaiely
south carolina
new holland 3930
i am in the process of adding on the house and doing most of the work myself.
i am installing a new electric water heater on a slab and do not want to set it directly on the concrete does anyone have any creative ideas with pictures!
   / hot water heater install #2
Afternoon tbaily,
I assume you want to get it up off of the slab because of any water problems in the future ?
In my basement I just used 2 -18"x 18" concrete blocks to raise the hotwater slightly off the floor. I dont have a picture but I think you get the idea ! ;)
My usit is a 50 gallon free standing unit. Is this the same type as your using ?
   / hot water heater install #3
No pics, but I've seen them set on bricks, one under each foot of the heater -- simple, cheap, durable.
scott_vt said:
Afternoon tbaily,
thanks for the replys that is what i was thinking of doing 3 bricks or blocks just to get it off the concrete to prevent the unit from rusting due to condensation. and yes i am using a 80 gallon free standing unit.
here are some before and after pictures of the project for those who are interested.
   / hot water heater install #7
Holy addition batman!! Nice job!
   / hot water heater install #8
I've always put a piece of polystyrene foam about 1 1/2"-2" thick to keep the cold concrete from sucking heat out of the water heater.
   / hot water heater install #9
Dont forget to plumb the pressure relief valve in.
   / hot water heater install #10
Fortunately you don't have to worry much about earthquake strapping. I go along with birdhunter1 and recommend the insulated pad to keep the tank high and dry above the concrete.
WESSEX CHT-100R-E LOT IDENTIFIER 222 (A53084)
WESSEX CHT-100R-E...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
HUTCH TANDEM AXLE (A51247)
HUTCH TANDEM AXLE...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51246)
2017 KOMATSU...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
