hot water heater install
   / hot water heater install #1
tbaiely
south carolina
new holland 3930
i am in the process of adding on the house and doing most of the work myself.
i am installing a new electric water heater on a slab and do not want to set it directly on the concrete does anyone have any creative ideas with pictures!
   / hot water heater install #2
Afternoon tbaily,
I assume you want to get it up off of the slab because of any water problems in the future ?
In my basement I just used 2 -18"x 18" concrete blocks to raise the hotwater slightly off the floor. I dont have a picture but I think you get the idea ! ;)
My usit is a 50 gallon free standing unit. Is this the same type as your using ?
   / hot water heater install #3
No pics, but I've seen them set on bricks, one under each foot of the heater -- simple, cheap, durable.
scott_vt said:
Afternoon tbaily,
thanks for the replys that is what i was thinking of doing 3 bricks or blocks just to get it off the concrete to prevent the unit from rusting due to condensation. and yes i am using a 80 gallon free standing unit.
here are some before and after pictures of the project for those who are interested.
   / hot water heater install #7
Holy addition batman!! Nice job!
   / hot water heater install #8
I've always put a piece of polystyrene foam about 1 1/2"-2" thick to keep the cold concrete from sucking heat out of the water heater.
   / hot water heater install #9
Dont forget to plumb the pressure relief valve in.
   / hot water heater install #10
Fortunately you don't have to worry much about earthquake strapping. I go along with birdhunter1 and recommend the insulated pad to keep the tank high and dry above the concrete.
2015 Ford Explorer SUV (A51694)
2015 Ford Explorer...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
PRO WORKS PWFF LOT IDENTIFIER 143 (A53084)
PRO WORKS PWFF LOT...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
HOMEADE PIN ON 2 PRONG HAY SPEAR (A51247)
HOMEADE PIN ON 2...
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
