hot water heater install
   / hot water heater install #1
tbaiely
south carolina
new holland 3930
i am in the process of adding on the house and doing most of the work myself.
i am installing a new electric water heater on a slab and do not want to set it directly on the concrete does anyone have any creative ideas with pictures!
   / hot water heater install #2
Afternoon tbaily,
I assume you want to get it up off of the slab because of any water problems in the future ?
In my basement I just used 2 -18"x 18" concrete blocks to raise the hotwater slightly off the floor. I dont have a picture but I think you get the idea ! ;)
My usit is a 50 gallon free standing unit. Is this the same type as your using ?
   / hot water heater install #3
No pics, but I've seen them set on bricks, one under each foot of the heater -- simple, cheap, durable.
scott_vt said:
Afternoon tbaily,
thanks for the replys that is what i was thinking of doing 3 bricks or blocks just to get it off the concrete to prevent the unit from rusting due to condensation. and yes i am using a 80 gallon free standing unit.
here are some before and after pictures of the project for those who are interested.
   / hot water heater install #7
Holy addition batman!! Nice job!
   / hot water heater install #8
I've always put a piece of polystyrene foam about 1 1/2"-2" thick to keep the cold concrete from sucking heat out of the water heater.
   / hot water heater install #9
Dont forget to plumb the pressure relief valve in.
   / hot water heater install #10
Fortunately you don't have to worry much about earthquake strapping. I go along with birdhunter1 and recommend the insulated pad to keep the tank high and dry above the concrete.
NEW HOLLAND TN75SA TRACTOR (A51247)
NEW HOLLAND TN75SA...
2010 JOHN DEERE 648H SKIDDER (A51246)
2010 JOHN DEERE...
VULCAN STAINLESS STEEL STEAMER (A51248)
VULCAN STAINLESS...
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51246)
KNOW BEFORE YOU...
