Hose Maintenance
/ Hose Maintenance #1
Machold
Wellandport, Ontario
Kubota B3030 & B7400
Can't find enough info on hose care & maintenance. Visual inspection tells me all is ok. But is visual enough? Any tips, advice, pointers? I hate the tought of hydraulic failure at the moment of lifting a load.
/ Hose Maintenance #3
Perhaps other members have a different method, but when I check the hoses visibly I checked for cracks, cuts, scrapes; especially where the hose bends. I also pay close attention to the area around the clamp area.:)
/ Hose Maintenance #4
YES> Any cyclic bending enforced around a hard or abrupt area. Also, any out of roundness in the cross section indicates a probably pinch and pressure cycling will have it leaking shortly. Cuts or scrapes generally dont damage the steel reinforcement, but you have to keep the weather out or the steel will degrade.
larry
/ Hose Maintenance #5
Even hoses that have cracks, doesn't mean that they are bad. There are a lot of hyd hoses that are over 20 years old, with cracks and still working the same with no leaks.
Ozone will affect the rubber on the hoses no matter what you do.
Covering the hoses with a protective sleeve or wrap will help some, but will hide leaks.
If one is that concerned about the hoses, then replace it, or at least have a replacement ready.
Bulk hose and replaceable fittings is a good investment for quick repairs.
Replacing hoses every time you see a crack will get very expensive .
/ Hose Maintenance #6
The extent of my inspection is just visual. But not really looking at the hose condition, rather looking for wet/oily areas that indicate a leak.
The outer rubber is only ONE part of the hose construction. There is an inner rubber liner, and a steel braid around that, and then the outer jacket.
With hydraulic hoses, I use the mentality, if it aint broke, dont fix it. Or rather if it aint leaking, dont worry about it.
I have seen hoses that looked terrible. Steel braids showing, rubber falling off, etc and they didnt leak.
I have also seen hoses that appeared BRAND new fail. Due to the interior liner failing.
/ Hose Maintenance #7
I think I have replaced just about every hose that came on my Vietman Yanmar rebuiltwith V3 FEL and every blown hose looked like new- no cracks worn spots, etc. just a pin hole blow out. I was surprised to see that all the hoses were made in USA. I cant remember what rating the original hoses had (maybe 2200 PSI )but all my replacement were rated higher PSI than the original hoses and I havent busted one of them yet.
/ Hose Maintenance #8
JJ, I have been having NAPA make up my hoses. I have been putting off replacing some hoses because of the cost involved. Can you point me to where I can order bulk hose and replaceable fittings? Is there a preferred brand/type of replaceable fitting? Can the hoses be made up without special tools?
/ Hose Maintenance #10
Thanks for the response JJ. After my post I did some more reading and found the discounthydraulichose website. As soon as I can verify the sizes I need and the quantities, I plan to place an order.
/ Hose Maintenance #11
yep.. check em over.. look for damage tot he rubber sheath.. IE.. metal innerds sticking out. they will rust fas tthat way.
look for kinking, or bulgeing.. loose dripping fittings.. a weeping fitting will collect dust.. and look dirty.
in chaff areas, use something like wire loom or fire hose, or similar ' netting style hose loom material to protect them.. bundle hoses with zip ties to keep them from snagging.. just make sure they have room to move at a pivot...watch pinch points and edges or flanges they may abraid on.. use a piece of split rubber line on the metal flange, held on with contact cement or zip ires..
I save old radiator hoses to cut pieces to use as zip tie bandaids to put on a hose where it may contact metal..
soundguy
/ Hose Maintenance #12
Be sure you match your hose and fittings correctly. Reusable fittings can only be used with specific hoses (SAE 100R2AT fittings with SAE 100R2AT hose, for example).
/ Hose Maintenance
OK, thank you, all. I'm worried about failure (without good reason) because I'm going to make a work platform to lift with the loader (pallet with railings).
2015 Freightliner M2 106 Petersen TL3 Forestry Grapple Truck (A61573)
2015 Freightliner...
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59912)
2025 PJ CC162 T/A...
2014 BMW X1 S28i SUV (A61574)
2014 BMW X1 S28i...
Case IH 950 Planter (A63688)
Case IH 950...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
