Hose bib leaking.
   / Hose bib leaking. #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Hi all,
I just got back from Lowes where I purchased a splitter for my outdoor hose bib. The thing leaks like no tomorrow.
I hand tightened it the best I could, but it leaked. I tightened it with a wrench, and it still leaked. I replaced the gasket with a new one, and it still leaked.
I checked out the end of the bib and there seems to be no problem with that either. Seems everything I attach to it leaks.
Do you think the bib is bad, or just the stuff I am trying to connect? Any quality products for hose connections out there?
This is the leaky little gem I bought.
Thanks
Dave
   / Hose bib leaking. #2
I have several of those from both Lowes and Home Depot. I have never had any problem with them. Maybe Lowes would allow you to return it for a new one?
   / Hose bib leaking. #3
Put a nozzle on the outdoor hose bib and see if it leaks with the nozzle turned off.
   / Hose bib leaking. #4
Did it come with a washer in the faucet end? If not install one. All that stuff is 100% Chineseum today.
   / Hose bib leaking. #7
@dj1701 I have had trouble with some of the splitters that I have bought until I replaced, or added an extra, gasket. On some, the original gasket was undersized (metric?), thin, and often leaked as a result.
These days, I know what my needs are, and I have taken to plumbing in multiple 3/4" ball valves with GHT adapters on them where I need multiple flows. The splitters generally have very small diameter openings that cut into the max flow possible for me, especially as my water pressure runs around 20-25psi at the taps.
All the best,
Peter
   / Hose bib leaking. #8
Agreed, the supplied washers seem to be undersized. I throw them away and put a rubber washer in there....the kind you have to fight with to get it fully seated. Problem resolved.
   / Hose bib leaking. #9
Sounds like a "bib" issue to me..
"I checked out the end of the bib and there seems to be no problem with that either. Seems everything I attach to it leaks."
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2025 CATERPILLAR 265 SKID STEER (A51242)
2025 CATERPILLAR...
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52128)
2022 New Holland...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
