sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,799
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
I mow 6 acres of grass with my JD2210. If I had an FEL it would easily manage your 2 acre tasks.
Not picking on Gary but he gave you a perfect reason to not buy too big. 8 year old tractor with less than 200 hours. Then he had to go buy the tractor he needed.
Rare to see that but it happens.
If only buying one tractor it's best to buy the size that will do ALL the tasks. Even if it means taking more time.
Yes but do to the extra turns involved
there is a fair size difference in some 55- 70 HP tractors.
my 55 hp tractor turns just as tight as my 40 HP Ford 3000 did. the only places it is really different is height and weight.
With the size of place the OP has- probably right about his smaller tractor being able to cover all the bases- unless the tractors both have FELs and he ever needs to lift anything heavy or op needs to use his Cat 2 implements.
so i would get the 55 horse tractor and get everything done and then if not needed trade or sell and get a smaller maintenance tractor
