Horsepower programmers
/ Horsepower programmers #1
ralanb
Horry County
Cat d-3, Cat 268-B (toasted), Cat 320, more to come.
Does anyone on here know anything about a programmer to increase the horsepower on a skid steer?
/ Horsepower programmers #2
If you have a mechanical fuel injection system, it ain't gonna happen with a 'chip'. Unless you have a very large SSL that is Tier III emissions compliant or a large SSL that is Tier IV compliant, it is probably a mechanical fuel system.
/ Horsepower programmers #3
Alan,
we are a dealer for programmers and what rick said unless its a big machine they don't make a programmer for it.
Thanks guys. Just seen where it as a tier II. Thanks anyway.
/ Horsepower programmers #5
All I know is that it doesn't make any sense to.
You HAVE all the power you can use, so WHY ?
Unless you have some other means to make it weigh more and/or lift more.....
Yeah, I still don't get it.
/ Horsepower programmers #6
If you are running a mulcher, you NEVER have all the power you can use.
Thank you fish factor. We do have added weight, and it helps with the steel tracks when we are pushing trees.
/ Horsepower programmers #8
Running a mulcher, you need every HP you can get. Personally, I was excited when Bobcat announced the 870. 99 HP and the much needed cab upgrade. Then I got into the specs. The high flow is only 34 gpm. I'm no expert, but my 320 is 40 gpm, so I think I would loose performance if I switched. Maybe not, but seems dumb for them to leave the high flow lacking.
Still interested in the lamtrac, or the fecon 148 if I can catch a tiger like cbturf.
Cb turf got it going on. I just hope that everything continues to go smooth for him so he can make it back to his family. Us small people need a good break every once in a while. I myself am waiting for this big bid openning. I will need help on it if i get this one.
/ Horsepower programmers #10
I'm not too far from you if you are in Horry County, SC. I'd be happy to help if we could work the schedules out.
Sounds great, i'm not to good to ask for help on jobs especially if there is enough to help some one else.
/ Horsepower programmers #12
I know nothing of the new computer programmers for the newer diesels. The old manual pumps generally were very easy to jack up the HP. Went to a Fairbanks Morris/Colt Pielstick school for our stand by diesel at a nuclear power plant. The question was asked how far you could turn up the HP on a diesel. The instuctor said there was not a definite limit. Jack up the diesel pumps, and add more boost on turbo air, but there was one variable. Of course we were all curious and had to have that variable. The instructor just told us that some would stand double the design HP and some would stand even more, but at some point they will all self destruct. All will have shorter life spans and burn more fuel when jacked much above design pressure. Exhaust temps have to be monitored or you will burn the tops off of the pistons.
The diesels we were learning about at Fairbanks Morris were 14 cylinders and you could crawl into a cylinder. They turned 500 RPM.
yall must have been on transport ships, not nuke plants, my god the generators produced more power than the plant. lol :)
/ Horsepower programmers #14
I've been retired 11 yrs, but if memory serves me correctly, the diesel units were 6.5 megawatt. Of course NRC/Tech specs required 2. Plant itself was a single unit 1150 megawatt and later improved/jacked up to over 1200 megawatt. That is a lot of power. Biggest coal burner I was ever in was 750 megawatt and the boiler was 300 ft tall. I think I'm getting a bit off the subject, but like to tell sea stories.
I may be off on the power of the emergency diesels. Not hard to forget when that is your goal.
Sunflower Yard Art (A64557)
Sunflower Yard Art...
7061CFL (A64553)
7061CFL (A64553)
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
Single Cylinder Hydraulic Grapple Bucket Mini Skid Steer Attachment (A64553)
Single Cylinder...
Dixie Chopper (A64557)
