Bucket Hooks Hooks on the FEL bucket
   / Hooks on the FEL bucket
Stopped at the dealer today and they will weld on three hooks for a small fee so will go with that. Their head mechanic advised me to be careful using the hooks on the end because it could warp the FEL. He stated the weight had to be evenly distributed or just use the center hook.
   / Hooks on the FEL bucket #32
Two directly in front of the loader arms is what they weld on buckets around here, they won't weld them on the ends, liability I guess.. Bending, tiping over etc..
   / Hooks on the FEL bucket #33
Good deal. And yeah omy welded hooks are in front of my loaders arms, but I still make sure the weight is even or use the center D ring like he's saying. You'll be glad you have them.
   / Hooks on the FEL bucket #34
so when welding on the bucket (or other) do you disconnect battery terminal(s) and/ or alternator connection?
or just use a good ground connection?
   / Hooks on the FEL bucket #35
Safest bet, just unhook from it
   / Hooks on the FEL bucket #36
If I was to do it, I would remove the battery connections, these things are all electronic these days..
   / Hooks on the FEL bucket #37
I have a slip hook in the center and grab hooks on each side of both my buckets for that very reason. He is telling you correctly. You want to pull centered.
   / Hooks on the FEL bucket #38
Just make sure GROUND CLAMP is firmly secured to item (bucket) you are welding on.... Disconnecting battery and such is probably extra but unneeded effort.... Check out what guys say in Welding Forum....
Any good welding manual will tell you to always put ground close as possible to where actual weld will occur... It does not mean put ground clamp on 3PH if you welding on FEL because 3PH is most convenient location...
Dale
   / Hooks on the FEL bucket #39
If it’s a QA bucket as most are nowadays, just take it off the loader.
Yamaha (A55758)
Yamaha (A55758)
2018 Ford Fusion Sedan (A55853)
2018 Ford Fusion...
(2) TRACTOR TIRES (A54757)
(2) TRACTOR TIRES...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
