Hooks On Both Buckets
/ Hooks On Both Buckets #1
dsvaleri
Westminster, Maryland
Kubota BX24TLB
I have read several threads that mention welding hooks on both buckets of a BX24. Would someone post some pictures showing the placement of the hooks? Is there any additional reinforcement add around the hooks?
/ Hooks On Both Buckets #2
Have you tried typing "bucket hooks" into the search feature?
/ Hooks On Both Buckets #3
I don't have any pics, but on the FEL its in the middle on top, point of the hook facing the operator and on the bucket its on the back of the bucket with the point facing up. I can snap some photos of mine when I get home if no one does in the mean time.
/ Hooks On Both Buckets #4
Here are a couple of pictures showing hooks on both the backhoe, and loader buckets. The hook is covered a bit with dirt in the pic of my old backhoe so you will have to look a bit closely to see it. The picture showing the stump chained in the bucket of my old BX shows one use of the hook, and you can see the center mounting that offcamber mentioned. The other pic shows another installation of bucket hooks on a larger tractor. Often the location, and number of hooks is determined by the hydraulic cylinder location, and number of cylinders.
/ Hooks On Both Buckets #5
I'd mount the hooks close to the 2 arm supports . Also, tractor supplies carry hooks w/bottom flats specifically made for mounting. Unless you're a welder with equip more than a buzz box, I'd recommend you having it done at a shop....you don't need a load breaking loose......bb
/ Hooks On Both Buckets #7
I Agree! Keep those hooks "in-line" with the loader arms. Do not place at the outside edges of the bucket. It's a good way to twist your loader and/or bucket.
/ Hooks On Both Buckets #8
You do want to place a set of hooks on the outside edge of the bucket. They are so handy to tie large bulky items into the bucket. I added mine just after moving this HVAC unit.
ron
/ Hooks On Both Buckets #9
Just wanted to add my two cents on the bucket hook question. I asked for three hooks on our bucket, one in the middle, and one at each end. They didn't want to put the hooks on the corners for fear of racking the loader arms with an off-center pull, but I assured them that I just wanted them for securing loads in the bucket, as shown in the last post. It's a great combination.
/ Hooks On Both Buckets #10
jimainiac said:
They didn't want to put the hooks on the corners for fear of racking the loader arms with an off-center pull, .
This is a good point and probably why my dealer put one in the center... and as stated as long as you use the outer ones only for securing loads its probably ok....
/ Hooks On Both Buckets #12
The below pictures are of the actual hook (U) tie down on the B26. :)
The Gotcha Man
/ Hooks On Both Buckets #13
Gotcha,
I'm not exactly sure how those tie downs pic's fit into this thread on bucket hooks, but thanks anyway.
ron
/ Hooks On Both Buckets #14
I asked my dealer to install hooks on the FEL of my GL3430. He put clevis type hooks on the sides near the top. I'm not crazy about them placed there, but I don't use them much anyway. I also had a single cylinder grapple put on the FEL. It turns out not to be as usefull as I hoped it would be, but it does make a great place to fasten a chain!
/ Hooks On Both Buckets #15
When I bought my tractor, I asked the dealer to put three hooks on it.
He said "where?"
I said "Ask your welder where everyone else gets them and put them there."
Problem solved, and the hooks are very useful.
/ Hooks On Both Buckets #17
I put mine in the middle at the top of the FEL in an already re-informed area. I just drilled through and bolted on a hook commercially available bolt on hook with 2 bolt holes. It's been there for several years with no signs of weakening. Welding may be better but the way I did it cost $7 .
Kubota SVL 97-2 Skidsteer (A65579)
Kubota SVL 97-2...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
2023 Case 75c FarmAll Tractor (A62679)
2023 Case 75c...
2021 Ford Econoline Box Van, VIN # 1FDWE3FN3MDC22817 (A65563)
2021 Ford...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
