hooks for bucket
/ hooks for bucket #1
GeneV
Elite Member
Lake County, IL
Bradley 48" stander MF GC1710
What size hooks are you guys welding onto your buckets? Is 3/8 big enough or should I go bigger? I just have a little massey scut, I'm not going to be doing anything crazy with it.
/ hooks for bucket #2
I went with home made for 1/4 inch chain.... Chain is 1200 lb test, have serious doubts tractor can exert enough energy to break it....
Parts just cut from 2 x 2 x 1/4 inch angle iron and grade 8 bolts...
Dale
/ hooks for bucket #3
I put 5/16" on mine, only because they apparently don't make 1/4" weld on hooks. Could have used regular hooks but prefer the weld on. The 5/16" will accommodate a 3/8" chain but doesn't get the full engagement like it should. Agree with DL about the capacity. No need for 3/8".
/ hooks for bucket #4
They do make 1/4 inch, but probably harder to find....
Dale
/ hooks for bucket #5
I rarely use anything other than 1/4" G70 chain any more. The WLL on it is 150% of what my loader will pick, and the breaking strength about 6X. Works in my 3/8" slots and is nice to handle too.
/ hooks for bucket #6
5/16... you can use 1/4 chain with it as well as 5/16. 3/8 is too large for anything under 40 horse.
/ hooks for bucket #7
Yep, 5/16 easy to find and cheap.
/ hooks for bucket #8
I mounted 2 of these HF tow hooks towards the top outside of my bucket.
I decided that this style of hook offered me the most flexibility of use.
I can use my nylon straps easily with these hooks.
I can also use my 5/16" and 3/8" (already had before tractor days) chains with these hooks by making a loop with the chain around the tow hook and connecting it to the chain.
My metal chokers with their loops on the end work also work.
Oh, I forgot, all of my chains have one end changed out to an open style hook like these so when I hook a log they will cinch up tight to the log.
KC
1???? lb. Capacity Tow Hook Kit
/ hooks for bucket
KC
Ooh, that's a good point, I should have also mentioned I tend to use ratchet straps more than chains. So you mounted this to the sides (outside near top) of the bucket instead of on top?
/ hooks for bucket #10
Instead of welding the hook to my bucket, I drilled a hole through the bottom of the bucket, a little bigger then the size of the chain. I then pass the bare end of the chain through the hole, and lock it with the hook so it will not go back through. The method seems to work a treat.
/ hooks for bucket
Hey guys, I asked it somewhere else too, but asking here, did any of you reinforce the top of the bucket when adding hooks? Would I need this for my little tractor?
I'm thinking 5/16 hooks on top, clevis ring under it on the other side. I guess no welding needed for that.
/ hooks for bucket #12
I was not clear, but I did mount the hooks to the top of the bucket, and I also used a piece of 1/4" flat bar inside of the bucket so that the bucket is sandwiched beteen the hook and the flat bar.
I also bolted a HF 2" hitch on the top of the bucket in the center, use it mostly with an insert that has a shackle.
KC
/ hooks for bucket #13
My little Iseki only weighs about half a ton, so I figured by the time I got a quarter of a ton hanging off the bucket, the back wheels are almost going to off the ground, and I don`t want to be going there. Also I though of getting the lifting point, as low as possible. If the load is hanging from high up, and a wheel drops in a dip, theres a bigger chance of the weight pulling her over. As by my previous post, I went for the hole in the bucket, no reinforcement, and I`ve not had any problems with distortion.
/ hooks for bucket #14
For lifting capacity around 700 lbs, I just bolted some Cold Shuts (chain menders) to holes I found already there.
This is a 2005 photo - and they have held up well.
39929d1118694307-hooks-bucket-673366-img_3091bucket-logs-jpg
/ hooks for bucket #15
Good idea. :thumbsup:
/ hooks for bucket
/ hooks for bucket
Yeh, weight low is a good idea. I moved a few loads with it dangling below the bucket with strapped wrapped around the hitch receiver tube I have on the bucket, that's all I have now in terms of that. Another thing I was thinking, d-rings installed bottom inside corners of bucket, d-rings or hooks top of bucket on each side, I could see that being pretty handy.
/ hooks for bucket #18
IF you are lifting wheels off ground with 500 pounds in FEL you need rear ballast weight...
Dale
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
Bobcat SC72 (A64127)
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
CASE 105C (A62177)
CASE 105C (A62177)
