Honda RT 5000
/ Honda RT 5000 #1
Locknut63
Ray,Mi
LS3039
I appears the charging system is failing. I installed a volt meter to keep track of things. So other day while using the tractor volts dropped off to about 9.5. Usually it’s 13-14. Then after to turned off voltage went back to 12.5. Anyway anyone have info on troubleshooting the charging system on this old over complicated tractor? Thx
/ Honda RT 5000 #2
Do you have the attached? Maybe the answer is in there. (y)
  • HONDA RT5000 TRACTOR 31752601.pdf
