Honda quad question
   / Honda quad question
Yea the I can hear the valves ticking at low speed, so am hoping that will help. Is there a alve cover gasket I will need? I live pretty remote and everything is a mail order item for me. If so I would like to have it in advance.
   / Honda quad question #62
You should be able to reuse your gasket. Most of my vehicles it is an o ring type gasket rather than a flat gasket. If you are hearing valve noise, you'll be amazed at the improved idle and shortened warm up times after proper adjustment.
I am aso getting trailing throttle popping as well which convinces me they are out of adjustment. So valve adjustment is next on my llist. Wil do that when I pull the panels back off to buff them out.
We have a funeral to attend Thurs, that's a couple hundred miles away, and have company coming here, Friday. Sooo, when it quiets down I can get back to my chores. I have a remaining 2/3 of a big oak tree to remove from a property in town, and a shed for my well pump and equipment, to finish as well.
Then I will get back onto the quad. Now that I know it runs, I can do the oil change, flush the brakes, and adjust the valves, then buff the plastic, and repaint the wheels and racks.
After that, I should be able to just enjoy the thing :)
   / Honda quad question #65
My neighbor has the same quad. Very tough and goes most places our 4x4s go. IDK how it is by you, but here is so rocky skid plates are a MUST. ALl it takes is one rock or stick and you're walking home. My friend knocked off his oil drain plug. I made one for my 88 TRX300 out of some steel from an old work bench top. Held it on with carriage bolts up thru some angle iron across the frame rails.
   / Honda quad question #66
I had to think about this as really there is no secret. I'm not particularly easy on my stuff so the only thing I can think of is that the Grizzy 700 gets started at least once a month and taken for a good run. Like at least 5-6 miles and most often more. The quad has never had a battery charger on it but any of my other equipment usually gets a small battery charger put on at least once or twice a winter. As soon as I notice that starting gets a bit sluggish I put the charger on for a few days.
Another "secret" might be that we live at least ten miles from any where. If a vehicle gets started it's gets twenty miles there and back so the alternator has a chance to fully recharge the battery after starting.
I have a camper with two RV battery's in it. I can think of at least twice that they have been totally dead and after a week on the charger they are good to go for the whole summer. They are around seven years old.
I've had troubles with my 2004 4410. It's on the third battery. First one was about five years, second about a year and now the last one. My 1949 IHC KB-1 only gets about two hundred miles a year on it and I usually get 5-6 years out of that six volt battery. It's the only vehicle with a battery isolation switch. If I leave it connected for sure the battery is dead.
On the vehicles that I drive regularly I usually get 8-10 years out of the batterys.
Knock wood, the original Yuasa battery in my '07 street bike is doing well. It spends the winter on an older VDC maintenance charger; it was one of the first with a patented de-sulphation function. If I'm not riding for a bit, in season, I'll throw it back on that charger for a stretch.
That, a bit of luck, clean battery terminals, and keeping the battery topped up with distilled water as needed is what I try to keep on top of. Some poorly regulated alternators can boil off electrolyte much faster than others.
On the other side of the coin.... some small engine alternators may be a bit low in output - battery may be somewhat undercharged all season; bad news if it's left like that over-winter.
When I eventually need to replace that bike battery, I'll look at Yuasa again in conventional batteries, as well as pricing an AGM solution.
Rgds, D.
Well, maybe I need to buy a better brand of battery. I do know that the engines get a lot of start stop so hard on the battery. Not much of my small battery items get more than 20 mins at a time running except for the lawn mower. I've wondered about those de-sulphation chargers but never bought one. Maybe I should put it on my list. :)
   / Honda quad question #67
OP seems to be at a pretty good point, for an early-stage overhaul, so hopefully doesn't mind a bit of drift... :)
Of the recent class of chargers, this style is one of my favourites:
CTEK Multi US 3300 | CTEK Battery ChargersCTEK Battery Chargers
Ctek 3300, in the North American listing if that url doesn't fire up....
Relatively small case (easy to fit into nooks/crannies), with good maximum output relative to case size. The case is well sealed (IP rated), so can handle rough weather, or on vehicle mounting.
It has a cold weather mode (alternators are temperature compensated to bump up charge voltage, as temperature drops), which is also a good match for charging AGM batteries. I've bought one of these, the next time I catch a good sale, I'll probably buy another I like it that much.
Bosch and one other manuf. I can't recall at the moment have similar types of products.
Rgds, D.
It depends on where I would take it. Not likely to go too far out, but one never knows I suppose. I will look to see if it has any skid plates. Never noticed. Might be something I could fab up too.
   / Honda quad question #69
Rgds, D.
Cool, I'll check that out.
   / Honda quad question #70
Not sure if it's possible on a quad but on my ATC I was able to modify the battery box to accept a standard garden tractor battery. They are a lot cheaper and go on sale often. Being 250cc it doesn't take much to turn it over but the added battery capacity really helps if you add a winch. My 250sx was very cold blooded. Anything below zero made it all but impossible to start without draining all the juice out of the battery. Unless the engine was at operating temps the kick starter was worthless. Rejetting the carb made a world of difference. Now it'll start on the second kick no matter how cold. If you have the same carb it'll have lots of adjustments. I bet I waited 10 to 15 years before adjusting mine. Wish I had done it sooner.
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
2006 Ford F150 (A50323)
2006 Ford F150...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
UNUSED FUTURE 7T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 7T...
1994 Alumatech Frameless Dump Trailer (A50514)
1994 Alumatech...
