Honda EB3500x Generator engine starting issue
   / Honda EB3500x Generator engine starting issue #1
rlrobinhood
Chester, MT
Kubota L4200
Hi all,
I recently pulled this old generator out of my dad's shed. It hasn't been used for many, many years but ran once. Anyways, I'm having a real hard time getting it to start. I replaced the carburetor, replaced the fuel line, replaced the shutoff valve, sparkplug, and air filter. I have confirmed there is fuel to the carburetor and confirmed there is spark.
I'm convinced it is a linkage/carburetor issue but just don't understand this carb. It has two butterfly valves in it. If I manually hold the linkage where the innermost (nearest the engine) butterfly valve open, I can get it to run for about 1-2 seconds then it cuts out. I suspect the outermost butterfly valve is staying closed and choking it out. But, I can't figure out how to determine if this is really happening. In the attached pic is a yellow arrow pointing to a vacuum pot that I think open the outermost butterfly valve. Is this what this does? The vacuum line goes to the green "thing" with the red arrow. What is this green "thing"? and then the vacuum line continues to the carburetor.
Can you help me out with these questions? Does anyone have one of these generators or carb/choke setups that could answer some questions for me so that I know the linkages are all correct? I believe they are.
Thanks so much in advance!
   / Honda EB3500x Generator engine starting issue #4
I sometimes begin with a splash of gasoline on the air filter element to see if it could run. Then a tiny wire pushed into venturi(?) from fuel bowl to check if it is clogged with varnish from old gasoline.
I reread your first post. You get it to run for a second or two after changing carb.
   / Honda EB3500x Generator engine starting issue #5
Sounds to me like the carb needs to be removed and given a soak in Berryman's B12 Chem tool. You need to remove all the internal parts and soak them as well. Just record the settings on the needle valves so when you put it back together you can set it back to what it was at and put an inline filter between the tank and the carb too.
   / Honda EB3500x Generator engine starting issue #6
In the OP's first post, he said this:
So I don't think that cleaning the carb is the answer.
   / Honda EB3500x Generator engine starting issue #7
rlrobinhood
The new carb you purchased, is it an exact replacement carb from Honda ?
Richard
   / Honda EB3500x Generator engine starting issue #8
I use a web site like ereplacement parts dot com they have specific models and exploded views with part descriptions.
   / Honda EB3500x Generator engine starting issue #9
A few questions.
- Do you have the throttle control connected and does it work ?
Throttle control
And I see that there is a fuel shut-off solenoid. Is this connected and does it work ?
Shut-off solenoid is #12.
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
2010 GMC Seirra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Seirra...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A56435)
1995 Ford F-250...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
