Nomad,
You call yourself an engineer, but I for one have my doubts.
I know for example, in Malaysia, a person who can call themselves an engineer would barely qualify as a technician here. Maybe you are an 'engineer' but a good U.S. engineer combines a healthy compromise of theory with real world results. Materials mean nothing if it isn't reliable.
How important is it that the material is ST37, ST52, or ST-UPID, if the **** thing breaks on the end user on the first day? Oh, thats right, in your prior post you said people should heat treat their China products. So if it broke and you didn't re-heat treat it, re-weld it, add missing bolts, tighten loose bolts, add new bolts and welds to areas that needed it, changed out 10mm bolts in 12mm holes to the correct bolts, ( Chinese equipment is notorious for oversizing holes so they can use whatever bolt is on hand, and allow for mis-alignment ), and finally add some real paint that doesn't come off with the first pine cone that hits it.
So if the end buyer didn't do all this, you are saying it isn't low quaility, it is the hobby buyers responsibility to accept this.
Most people need to devote all their attention to being an engineer to be a good one. Seeing that you claim yourself
to ALSO be a trader, businessman, etc, says it all. /forums/images/graemlins/crazy.gif
