homemade SSQA adapter build pics
   / homemade SSQA adapter build pics
Forgot to mention the pallet forks. They worked fantastic. I got them as used rental units and fixed them up. $450 was a steal imo. Only issue was they're rated for around 4k lbs. So they weigh upwards of 350lbs I believe.
I was going to sell them and buy something lighter before I decided to do the next best thing. Buy a bigger tractor instead haha
   / homemade SSQA adapter build pics #22
It seems like they'd be very handy for moving stuff around the property. I imagine with the weight of the forks and the limits of your 855 loader, you were pretty limited on how much you could lift. Did it handle lifting a pallet tote full of hardwood fairly well? I really like that idea for moving firewood around.
The 855 had good capacity for its size, but would not lift a full crate. That was one of the reasons for the new tractor
   / homemade SSQA adapter build pics #24
I'm on the fence between ssqa mounting my truck snow plow to my FEL or building a tractor frame mounted bracket for the plow. I like the idea of not having to remove the FEL, but fear that it may not work as well as a frame mount. I see people argue both ways. As someone who has experience with a tractor roughly the size of mine, how did you feel it performed?
   / homemade SSQA adapter build pics #25
Looks great. Nice job.
I sold the SSQA plow because it was just too much for the 855. It was larger than the craigslist ad said it was, but the price was right. I used the snow blower or back blade and bucket with that tractor. I built a snowpusher for the LS that works well.
Jay
   / homemade SSQA adapter build pics #27
I know this is an old thread but as a recent owner of a JD855 I found this very interesting. The OP did a remarkable job of improving this little machine.
I also need to move firewood and will be using a TSC carry all to lift cut down pallets with the 3 pt hitch. The FEL will not lift nearly as much and I am stuck with clamp on pallet forks which make it even worse.
I wish I had 10% of the talent and skills of the OP. Again, great job!!
10' CONTAINER (A52706)
KBH Tender Trailer (A56438)
KBH Tender Trailer...
19010 (A55851)
19010 (A55851)
TEST YOUR BID BUTTON! (A60430)
TEST YOUR BID...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
18ft T/A Flatbed Trailer (A59231)
18ft T/A Flatbed...
