homemade SSQA adapter build pics
/ homemade SSQA adapter build pics #1
JLwoodworks
Macedon,New York
LS XR3135HC
Built an adapter to convert the 70A loader on my 855 to SSQA. Thought id share some build pics
Jay
[/url]Skid steer quick attach by jlaws1, on Flickr[/IMG]
[/url]20140614_214600 by jlaws1, on Flickr[/IMG]
[/url]20140615_112220 by jlaws1, on Flickr[/IMG]
[/url]20140615_120238 by jlaws1, on Flickr[/IMG]
[/url]20140617_185051 by jlaws1, on Flickr[/IMG]
[/url]20140618_213904 by jlaws1, on Flickr[/IMG]
added a receiver tube to move trailers
[/url]20140619_175115 by jlaws1, on Flickr[/IMG]
[/url]20140619_202318 by jlaws1, on Flickr[/IMG]
[/url]20140621_203813 by jlaws1, on Flickr[/IMG]
[/url]20140622_122150 by jlaws1, on Flickr[/IMG]
[/url]20140622_163027 by jlaws1, on Flickr[/IMG]
more pictures here
https://www.flickr.com/photos/98530813@N07/sets/
/ homemade SSQA adapter build pics #2
Beautiful work!
/ homemade SSQA adapter build pics #4
Looks good! Do you find it hard to see the ball to hitch up your trailers? There is no way I could position on in the center of my loader like that & see it. I have made a mount for mine on the outside of the mount to where I could see it.
/ homemade SSQA adapter build pics #5
Wow super job!
Thanks for the compliments
Oliver,
It can be tough to see, but if you stand up a little it's no problem. The big help here is that it's open through the center as opposed to one of those full plate receiver attachments.
I would think one of those magnetic base hitch alignment flags would solve the problem
Jay
/ homemade SSQA adapter build pics #8
Very nice work JL,, and well documented,,
I was going through your photo's and noticed on your JD, you made your own quick disconnect
for your loader, looks like you "added" a loader to your machine also,
Do you have a link where I could take a look at those picture's,
I didn't notice them on flickr.
/ homemade SSQA adapter build pics #9
Very impressive, Jay. I think you should change your ID to JLwoodandmetalworks. :thumbsup:
How do you cut your plate? The edges are so clean, looks like a plasma cutter, or some outstanding work with a torch.
Skyhook,
The loader is the 70A quick detach loader that came on the tractor when I bought it. . 2 handles and 4 hoses and it goes on and off.
Threepoint,
Thank you. While wood is one of my main fabrication materials, I do enjoy building all sorts of things.
All the cut edges are either a factory sheared edge, or one of my cuts with a portaband. Unfortunately I do not yet own a horizontal band saw or plasma cutter. Everything is cleaned and deburred with a flap wheel on a right angle grinder before paint.
Jay
/ homemade SSQA adapter build pics #11
My problem with seeing is not the loader but rather the the tractor it's self. It does not have a slopped hood & being a 6 cylinder engine sticks out there a ways.
/ homemade SSQA adapter build pics #12
That is a nice build. How has it worked out and any more pictures?
Thank you. It worked out great. My favorite addition to the tractor. In typical fashion I outgrew the tractor and traded it in. Guy at the dealer thought it was a factory made piece. All the pics I have are in the link at the end of the first post.
Jay
/ homemade SSQA adapter build pics #14
Jay
So im assuming the new tractor came with a SSQA? Or will you be making another? GREAT JOB BTW
New tractor is already compatible. Now I just get to make attachments! Made a snow pusher last year
/ homemade SSQA adapter build pics #16
JLWoodworks---Do you use a 1/4' or 3/8" backing plate for attachments? I'm thinking of making a couple of things skid steer adaptable but not sure which to go with.
I've never actually bought one. I've made everything from scratch. It really depends on the attachment. Where the stress points are etc.
/ homemade SSQA adapter build pics #18
Nice work... I actually posted a question regarding making vs purchasing the ssqa. I guess I should have looked a little more first. I think I will tackle it. How did the forks work on your 855? I have a Kubota L2250, similar size. Seems like they'd be handy.
/ homemade SSQA adapter build pics #19
BTW, awesome idea for the firewood bins. I assume that's just hog or cattle panel around the pallets. I'm gonna have to make some of those.
They have the latch boxes made that you can buy, but none of them suited my application exactly. Plus the challenge is fun.
Thanks I'm very happy with the bins. Just the 16' x 50" cattle fence from tractor supply. 20ga metal angle screwed to the pallet to weld the fence to.
