Homemade Log Grapple
/ Homemade Log Grapple
Hi Scott
I just got back up to the mountains last night and have not been on the forum for a while.
The grapple works great. You can pick up a twig with it in the pincers and place logs wherever you want. you can pick up multiple logs or individual logs. To change direction of pick you just open the grapple, put one side against the ground or any object and pivot the PT and rotate the pick 90 degrees. I have not rigged it for the back end yet, may do that this Summer.
I attach a pick of it coming up a steep hill with a 15 foot log. If you want to build one I can lend you the patterns for the steel grapple parts.
/ Homemade Log Grapple #25
Love the grapple design. Would you be willing to share you drawings?
Thanks
John
Great work! I too would love to have the drawings,this,looks like a great design,I've been trying to find time to design one myself,but it looks like yours is better than what I would have come up with.
/ Homemade Log Grapple #26
Looking at your 425 do you have the wheels reversed as there looks to be more space between the tires and the pt frame than I have on mine?
/ Homemade Log Grapple #27
I just signed on, as I am building(or should I say trying to build) a similar grapple. At this point I have not figured out the way to have one "claw" by-pass when they close. The variables seem to be the length of each "claw" from the pivot to the tip, and from the pivot to the cylinder and cross bar. Any info would be greatly appreciated, thanks. For now I will keep playing with my mock ups.
IH606logger
/ Homemade Log Grapple #28
Welcome to TBN. The original poster hasn't been active for about 6 years. But maybe he'll come back.
Look at the 3rd picture he posted. You can see that one claw is narrower than the other and fits inside it when closed. Hope that helps.
244649d1325607462-homemade-log-grapple-051-jpg
/ Homemade Log Grapple #29
I did notice that, but the problem comes when you bring the tips together the narrow one must come up first soas not to hit the tip of the other. This means that you either make it considerably shorter, or it needs to come up faster than the other. Tomorrow looks to be a wonderful day to work on that puzzle. Thanks for the reply.
/ Homemade Log Grapple #30
Hmmm... gotcha. How to make them close in the same order each time you close them?
/ Homemade Log Grapple #31
You just need enough of a guide / support for the grapple claw so that with both claws at their limits they pass. I would suggest that you don't need/want tight tolerance. e.g. imagine a three fingered claw. It will grab material just fine.
Did that help? Most commercial grapples don't line up exactly.
All the best, Peter
/ Homemade Log Grapple #32
Made this grapple a few weeks ago. Did the drawing in inkscape then used sheet cam to make the machine code for the cutting. Made it out of 3/8 AR steel scrap. Wanting to make a bigger version with longer arms to grab 48 inch and bigger logs.20180707_123219.jpeg20180707_165553.jpeg20180702_094925.jpeg
/ Homemade Log Grapple #33
Horse Weathervane (A61574)
Horse Weathervane...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
KUBOTA 60" PIN ON BUCKET (A64280)
KUBOTA 60" PIN ON...
2004 JCB 8017 EXCAVATOR (A64279)
2004 JCB 8017...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
