homemade DIY vavle spring compressor
   / homemade DIY vavle spring compressor #1
parluskq
wise va
honda 5013
Here is a video of a valve spring compressor I made...It only has to work two time lol
   / homemade DIY vavle spring compressor #2
I just rebuilt a small block chevy, I made compressor out of some pliers I got from tractor supply(the ones below). I cut the jaws, and extended them. I pretty much left the lower jaw as is, just extended it out, it presses against the valve face. The upper one I made taller, then extended it out, and then welded a large thick washer on the end that would press around the valve spring cup, and leave room for the valve stem and keeper to poke up though so I can grab the keepers. I found most all of them I had to strike the top of the valve with a plastic hammer first, the keepers get stuck in the grooves.
   / homemade DIY vavle spring compressor #4
I got a nephew who keep sayings his time is worth money. He'll spend $20 before taking 30 minutes to look or make something he might need. Me on the other hand, have more time than money and will spend hours trying to save $20.:thumbsup:
   / homemade DIY vavle spring compressor #5
Edit; My homemade compressor is for when the head is off the engine. I looked a little closer at the original poster's compressor, looks like his will work with the head still on the engine. Don't forget to put compressed air in the sparkplug hole when using his invention.
   / homemade DIY vavle spring compressor #6
I wouldn't have thought of the C clamp. It looks good to me.
I just left the head off and put a 2x4 across the valves and used wood clamps to hold them down.
   / homemade DIY vavle spring compressor #8
Nice Build... But I would have just gone to Auto Zone and used their free tool rental...
Our local one didn't have one...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
(1) 48"X18' ADS DRAINAGE PIPE (A60432)
(1) 48"X18' ADS...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2400 (A60432)
2400 (A60432)
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
