Home-made crawler
/ Home-made crawler #1
tree grower
Cuttingsville, VT
Ford 1210, Bobcat 742B, John Deere 1050
I have the transmission and differential for a Ford 1700, from the bell housing to the PTO. No engine, no front end, no steering, no tin. I hate to see something like this go for scrap, and it would take a long-term posting on ebay to find a buyer. Why couldn't it be made into a crawler? Use frame rails to connect the rear axle housing, bell housing, motor mounts, and radiator. Use a 22R Toyota motor, power a hydraulic pump off the front of the engine, use 16" junk tires, rubber tracks from a mini excavator or half tracks from an old Ford tractor--you get the picture. Are there plans for something like this, or has anyone tried it and would like to share their experience
/ Home-made crawler #2
I'd say go for it!!!!!
It will take more money then you think, take ten times as long as you could ever imagine, and eat up allot of space while you are working on it, but the results could be something really cool.
Of course, sometimes it's just better to get rid of that extra stuff and focus your time, money and energy on what you realy need to do, and not on what sounds like fun.
I have one of those projects in an old jeep. It's been years of tinkering to get it to the point it's taking up space in my shop and in the way. When it's muddy out or I just don't feel like doing anything else, I spend a few hours on it. Then it sits for a few weeks or even months.
Good luck,
Eddie
/ Home-made crawler #4
Fordson had these in the 1920s
My DIL's father has a 1982 Ford 1700. Nice tractor. That 2 cyl Shibaura diesel cranks out abuot 23 hp (pto).
/ Home-made crawler #5
I'm voting for the cub cadet crawler.... what a magnicificent looking piece. I would bet viewers take a step back in time and try to figure if their dealer ever knew they existed.
/ Home-made crawler #7
Tree Grower, That would be crazy cool. And crazy hard work. But again-crazy cool.
/ Home-made crawler #8
I copied these links because I saw this some time ago, This is the best explination of how to build a track vechical I have ever seen. These are a must view if your considering building one. Ther are 4 vidieos hear
http://sclipo.com/outer_flvplayer_new.swf?file=SWX2V8R4I0&video_type=O
http://sclipo.com/outer_flvplayer_new.swf?file=DWL2T8E6X5&video_type=O
http://sclipo.com/outer_flvplayer_new.swf?file=OWT2C8E7U0&video_type=O
http://sclipo.com/outer_flvplayer_new.swf?file=UWY2E8Q7I1&video_type=O
/ Home-made crawler #9
Wow! That little Sherman tank is awesome. That would be really cool to drive in parades. Some of his design ideas are really ingenious too. The suspension guide rollers are ace. Replace the wood and plastic components with metal and it could do tractor work. Rubber belt transmission is cool but probably wouldn't hold up to tractor work. Hydraulic motors is the way to go for a tractor application.
/ Home-made crawler #11
years ago I saw for "low cost" home made crawler tracks was to find some nearly wore out large Ag tractor tires and cut the side walls off and use the tread stretched over two rubber tires for bogie's, and drive, never tried the idea but it seems like it should work well,
