Homade cant hook (with photos)
   / Homade cant hook (with photos) #1
jwmorris
Sorry about the first thread had problems uploading the photos here.
In anycase I decided I wanted a cant hook and made one this evening. It was made from a drop from an old rollcage 1.75" OD 1.5" I'd tubing. The bottom 4" is 1.5" bar stock drilled and tapped on the bottom 3/8-16 to hold the "grabber" part, made two versions out of 1/2" stainless steel. I also was not sure if I just wanted a cant hook or a timber jack, so I drilled and tapped two more holes and made the "jack" part too.
Was not exactly sure where to put the pivot so I made different locations for the "claw" to mount. The extra grade 8 bolt at the to end is just incase I need it if the aircraft ball detent doesn't hold up (it is quite strong but hollow).
   / Homade cant hook (with photos) #2
That looks really nice in both construction and paint finish. Good job.
   / Homade cant hook (with photos) #3
Looks very handy indeed.
   / Homade cant hook (with photos) #5
What is that built from? Looks very simple and very practical. Any more details?
1 3/4" .125 tubing, 1.5" bar stock at the bottom, 1/2" bar stock for the contact point, 1x1/4" cold rolled for the pivot clevis and cut the hook from 3/8" steel.
   / Homade cant hook (with photos) #7
Very nice work!!
Some logging trivia -- as shown in the last photo it's a "timber jack". Take off the kickstand and it's a "cant hook". Put on a pointed tip and it would be a "peavey". Logging tools have funny names, that go way back. There are dozens of others.
So for bonus points, maybe you can make a pointed tip and make this a three-way tool!!
2007 MACK CXN TANDEM AXLE DAY CAB (A53426)
2007 MACK CXN...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2011 Ford F-150 4x4 Pickup Truck (A51692)
2011 Ford F-150...
Alliance Flotation Tire (A50123)
Alliance Flotation...
2005 National RV Inc. Dolphin LX RV (A53117)
2005 National RV...
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2022 CATERPILLAR...
