jwmorris
- Joined
- Oct 3, 2007
- Messages
- 1,203
Sorry about the first thread had problems uploading the photos here.
In anycase I decided I wanted a cant hook and made one this evening. It was made from a drop from an old rollcage 1.75" OD 1.5" I'd tubing. The bottom 4" is 1.5" bar stock drilled and tapped on the bottom 3/8-16 to hold the "grabber" part, made two versions out of 1/2" stainless steel. I also was not sure if I just wanted a cant hook or a timber jack, so I drilled and tapped two more holes and made the "jack" part too.
Was not exactly sure where to put the pivot so I made different locations for the "claw" to mount. The extra grade 8 bolt at the to end is just incase I need it if the aircraft ball detent doesn't hold up (it is quite strong but hollow).
