Homade cant hook (with photos)
/ Homade cant hook (with photos) #1
jwmorris
Sorry about the first thread had problems uploading the photos here.
In anycase I decided I wanted a cant hook and made one this evening. It was made from a drop from an old rollcage 1.75" OD 1.5" I'd tubing. The bottom 4" is 1.5" bar stock drilled and tapped on the bottom 3/8-16 to hold the "grabber" part, made two versions out of 1/2" stainless steel. I also was not sure if I just wanted a cant hook or a timber jack, so I drilled and tapped two more holes and made the "jack" part too.
Was not exactly sure where to put the pivot so I made different locations for the "claw" to mount. The extra grade 8 bolt at the to end is just incase I need it if the aircraft ball detent doesn't hold up (it is quite strong but hollow).
/ Homade cant hook (with photos) #2
That looks really nice in both construction and paint finish. Good job.
/ Homade cant hook (with photos) #5
What is that built from? Looks very simple and very practical. Any more details?
1 3/4" .125 tubing, 1.5" bar stock at the bottom, 1/2" bar stock for the contact point, 1x1/4" cold rolled for the pivot clevis and cut the hook from 3/8" steel.
/ Homade cant hook (with photos) #7
Very nice work!!
Some logging trivia -- as shown in the last photo it's a "timber jack". Take off the kickstand and it's a "cant hook". Put on a pointed tip and it would be a "peavey". Logging tools have funny names, that go way back. There are dozens of others.
So for bonus points, maybe you can make a pointed tip and make this a three-way tool!!
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2008 CATERPILLAR 320DL EXCAVATOR (A60429)
2008 CATERPILLAR...
154 (A52708)
154 (A52708)
Deere 310SK (A57148)
WOLVERINE PT-16-01C 3PT HITCH ADAPTER (A60432)
WOLVERINE...
2015 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A60429)
2015 CATERPILLAR...
