Holding Solenoid
/ Holding Solenoid #1
tshep
Richmond, VA
BX23 MLB
I want to:
Apply pressure (up to 2000 psi or so) by other means, hit a maintained electric switch, and have the pressure hold in that line until switch changed (- oh for $25!); a remote operated valve.
But yet reliably and inexpensively.
Suggestions?
/ Holding Solenoid
You all were supposed know I was kidding about the $25.
Can anyone suggest a vendor/site?
And maybe nomenclature/basics I need to know?
My best guess would be (holding) solenoid, maybe 'electric over hydraulic' too?
THX!
/ Holding Solenoid #4
I would suggest Surplus Center as well, particularity this one. Not knowing your voltage or flow requirements makes it a guess, but it's closest to budget.
/ Holding Solenoid #5
I want to:
Suggestions?
That’s a recipe for trouble if installed on an open center system.
/ Holding Solenoid #7
I don't get the "by other means" - why? Why not just use a electronic solenoid to open the hydraulic circuit and instead of using a momentary switch (like a typical third function setup) use a toggle switch so it'll stay open until you flip said toggle back?
For example:
12V DC Tandem Centre DO3 Directional Control Valve | Princess Auto
- That example has a neutral position (all circuits closed) and then open positions in either direction. (Like a rear remote on a tractor basically) So a 3 position toggle would operate it.
E.
2013 Chevrolet Silverado Service Truck (A62613)
2013 Chevrolet...
LOOK! (A63116)
LOOK! (A63116)
2022 EZ-GO ELITE...
2006 Dodge Charger Sedan (A64557)
2006 Dodge Charger...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2022 EZ-GO ELITE...
