Holding Solenoid
/ Holding Solenoid #1
tshep
Richmond, VA
BX23 MLB
I want to:
Apply pressure (up to 2000 psi or so) by other means, hit a maintained electric switch, and have the pressure hold in that line until switch changed (- oh for $25!); a remote operated valve.
But yet reliably and inexpensively.
Suggestions?
/ Holding Solenoid
You all were supposed know I was kidding about the $25.
Can anyone suggest a vendor/site?
And maybe nomenclature/basics I need to know?
My best guess would be (holding) solenoid, maybe 'electric over hydraulic' too?
THX!
/ Holding Solenoid #4
I would suggest Surplus Center as well, particularity this one. Not knowing your voltage or flow requirements makes it a guess, but it's closest to budget.
/ Holding Solenoid #5
I want to:
Suggestions?
That’s a recipe for trouble if installed on an open center system.
/ Holding Solenoid #7
I don't get the "by other means" - why? Why not just use a electronic solenoid to open the hydraulic circuit and instead of using a momentary switch (like a typical third function setup) use a toggle switch so it'll stay open until you flip said toggle back?
For example:
12V DC Tandem Centre DO3 Directional Control Valve | Princess Auto
- That example has a neutral position (all circuits closed) and then open positions in either direction. (Like a rear remote on a tractor basically) So a 3 position toggle would operate it.
E.
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
3145 (A63117)
3145 (A63117)
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
2022 EZ-GO ELITE...
