Hoe pin question
/ Hoe pin question #1
andyspain
Spain (Asturias)
JM284
Hi gents. I read here that the banjo pins that stop the pivot pin from turning are not much good. Well, all seem well except the one that takes the most stress, the bucket curl. What I want to know is why must the pin be fixed, why can't it be allowed to rotate, with just a large split pin where the banjo sits? Had a look at my hydraulic pump today, there are some unhealthy lines inside the body, but I don't think that's my problem.
/ Hoe pin question #2
I believe it will wear on the metal ends vs dispersed across the pin. Once that wears, not much you can do, except welding and re-drilling. I haven't tried it, but think you could find some eye bolts that would fit and be stronger. Might have to shorten to fit.
/ Hoe pin question #3
Hi Andy, Yeh the keepers for the pins are kinda soft..I have rolled and broken 5 or 6 of em.I thought that after some use the pins would get a little looser and stop rolling. I replaced them so far with some 5/16" eye bolts that I cut the ends off to make em shorter.Their about $1.29 at the local hardware store..I have a "Genie" manlift that uses the same pin keepers but they are 3/8" and hardened.maybe someday I'll find some hard 5/16" ones. Or even try getting them "RED" hot and oil quenching them to see if it helps. /forums/images/graemlins/smile.gif
/ Hoe pin question
Thanks gents. I did harden the pin, but it still bent. I'm picking up large rocks and the hoe is very strong to say the least, so it's understandable. If there are no short term wear problems I'll let the pin rotate and I'm rid of the problem. I do grease regularly. Well, thanks again
/ Hoe pin question #5
I just welded mine with a few beads. Nothing a grinder cannot remove if need be.
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2013 C&M TRAILER CHLORINE DIOXIDE MANIFOLD TRAILER (A67714)
2013 C&M TRAILER...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
2013 KUBOTA SVL 90-2 SKID STEER (A65056)
2013 KUBOTA SVL...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
