Hobart Handler 125 EZ
/ Hobart Handler 125 EZ #1
petra79
N.W. Ind
Ford 861 - Farmall C
I've had this welder for about 3 years now. Its starting to surge when it warms up. Its like the wire pulsates. Makes for a terrible looking weld with lots of air pockets. Any one ever heard of one doing this?? Any ideas??? I am not a welder by any means. Just try to fix my own stuff and do small projects.
/ Hobart Handler 125 EZ #2
I am not much of a mig guy, so take this for what it's worth. It sounds like your drive rolls might be slipping. I think that could either be bad adjustment, badly dirty liner, or worn out/plugged rollers. Are you running coated wire? Are you running knurled/serated drive rolls?
/ Hobart Handler 125 EZ #3
Replace the liner and you should be good, if you are cheep pull the liner out and clean it in a pan of nafta. I know I can't spell, it is a paint thinner. Cleaning works most of the time.
Thanks for the input guys. This one is flux core wire, no gas. Don't think its coated wire. I'll look at the rolls. that could be an issue since its adjusted all the way. No more room to tighten.
As far as the liner. Is this what the wire rides in inside the rubber going to the gun?? I'm not much for spelling either. I know what you're talking about though. I have some here.
If I need to replace the rollers, where is a good place to get them that won't cost an arm and a leg. Guess the cheap comment fit pretty good, eh???
Sorry for taking so long. Spring time projects have taken over. Did finally have to use the welder yesterday and strangely enough, it worked great?????????????
/ Hobart Handler 125 EZ #6
Flux core wire usually makes a liner dirty the fastest as flux core is not as clean and pure as the wire that is used with gas mode. So that is likely your trouble if problem returns since you have been using it 3+ years.
The liner looks like an old time throttle or choke cable on a tractor or mower. The liner runs the entire length of your lead hose (ie. from the machine to the gun).
Usually costs around $17 - $22 or so to buy a new liner. Or sometimes, as has been pointed out, you can get lucky and soak the liner in solvent like Naptha and clean them to remove the dirty residue. Often though a kink or deformation of the liner has occurred (e.g someone stepping on it or laying heavy object on it). If the liner is deformed, then replacement is the only fix.
/ Hobart Handler 125 EZ #7
Are you using the right size and type drive rolls for the wire? You shouldn't have to tighten the drive rolls all the way. That could be causing the problem and deforming the wire so it binds in the liner and/or contact tip. It would also cause little bits of wire to flake off and plug the liner. Flux-core should use a knurled drive roll and need very little tension since the knurled part will grab the wire a lot easier than a smooth drive roll.
Using .035 wire. Says to use that or .030.
On the liner, what's procedure for getting it out to clean?? Might just go ahead and try that.
/ Hobart Handler 125 EZ #9
Out of curiosity but did you happen to kink the hose to the gun while you were welding? On my handler if you get a tight bend in the hose it causes the wire to slip on the rollers because of the added tension from the tight bend. Straighten the hose and it works fine.
Can't say that it ever got kinked. The way we have it set up in the shed it would be kind of hard to have that happen, though anything is possible. Might have happened to one of the boys and didn't cause an issue at that time so nothing was mentioned.
Going to be using it again hopefully in the first few days of the week if I have spare time. We'll see if its still working ok or back to causing an issue.
Thanks for all the comments and suggestions. Much appreciated.
/ Hobart Handler 125 EZ #11
Looks like it uses an H9B MIG gun. Not sure if it's a the same as a Miller M10 or M100 but they're all very similar. Should show in the manual how it comes apart or you could probably find it on the internet with a little checking. I think there might be a set screw that holds it in on the plug that goes into the welder. Loosen the set screw and with your gun laid out in a straight line pull it out from the machine end(not the tip end). Take the nozzle off and diffuser holding the contact tip off. When the liner goes back in it has to fit inside the diffuser. It's easier to put the liner in first and then screw the diffuser back on.
Just to add, you will probably have to trim the liner to length. It should fit up to the diffuser but not so tight the diffuser is hard to thread on. Cut it with a good pair of side cutters.
/ Hobart Handler 125 EZ #12
If it been 3 years- I'd replace the liner as it probably rusted already. I bought a few replacements liners on ebay for my 125 ez.
Thanks guys.
GYRO-TRAC (A65053)
GYRO-TRAC (A65053)
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
2015 Kubota L6060 (A64126)
2015 Kubota L6060...
1990 Ford 3930 Tractor (A65579)
1990 Ford 3930...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
