hiring someone to make hay
   / hiring someone to make hay #11
The other day I saw a guy baling hay with a HUGH baler. The bales were rectangular - probably 5-6 feet wide by almost 10 feet long and 6-7 feet high. They had very marked crowned tops. I'll bet each bale was at least 6-8 tons. Like to see what is used to move those bales - - -
   / hiring someone to make hay #12
oosik
Crowned tops sounds like a hay stacker not hay baler. Hesston & JD made stackers back in the 70's-80's.
   / hiring someone to make hay #13
I'm pretty sure that's illegal except in Nevada.
   / hiring someone to make hay #14
Tx Jim,
Those thumbnails are the same thing I saw him using. First time I ever saw anything like that. He was using it to put up very thick, heavy bottom land field grass.
   / hiring someone to make hay #15
I sold one of the JD model 200 stackers back when I worked for a JD dealer.
   / hiring someone to make hay #16
I guess I am lucky, going on the fourth year of a 50\50 split per field -- Orchard grass and clover. Small square bales.
I pick mine up by myself, and when he comes back for his I help him pick his up.
We just do the first cutting, I like to stockpile and usually don't need to feed hay till after New Years.
---------J
   / hiring someone to make hay #17
What's a reasonable price for someone to come in and make hay for you? bales will be 1000# round don't know if 4' or 5' wide. would they normally price on a per bale price?
I bet OSU has a custom rate structure for farming ops.
I charge on the MSU custom rate schedule on custom work. Even calculates fuel usage.
   / hiring someone to make hay #18
How much hay are we talking? 2 acres or 200 , makes a big difference
I won't bother with any custom work less than 5 acres. Too hard to turn equipment for one and just not financially worthwhile.
When I started out years ago, I cut anything, didn't matter if there were logs in the field but then I had a sickle bar mower conditioner. I own very expensive disc machines now, high end bailers and rotary rakes and I never take any job thats not mostly rectangular straight line running and is free of trash. I walk a customer's field first before I even think about pricing anything. If there is trash in there, it's see ya later...
Fot a couple acres of grief, I'd charge accordingly and probably a lot more than 55 a bale.
   / hiring someone to make hay #19
When I worked on a farm in the 80's he had a stack mover. It used the 3 pt to lift along with hydraulic powered wheels to lift. It had a set of tines on the bottom to lift. It was all a 4020 could do to move it. That w as for the 100 stacker. The 200 was twice as big and stacks had to be fed where they were unloaded. Too big to move.
   / hiring someone to make hay #20
Normally break it down
$16 - acre mowing
$12-acre raking
$6-7 per bale for baling
Some just prefer to pay $75/hour for the whole job
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2020 Big Tex 22GN25T5 30' Gooseneck Trailer, VIN: 16V6X2528L6050344, Tandem Axle, Wood Deck, Bad (A59076)
2020 Big Tex...
(INOP) MASSEY FERGUSON 2614H RIDING MOWER (A58374)
(INOP) MASSEY...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
John Deere 5075E (A53317)
John Deere 5075E...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
