hiring someone to make hay
   / hiring someone to make hay #11
The other day I saw a guy baling hay with a HUGH baler. The bales were rectangular - probably 5-6 feet wide by almost 10 feet long and 6-7 feet high. They had very marked crowned tops. I'll bet each bale was at least 6-8 tons. Like to see what is used to move those bales - - -
   / hiring someone to make hay #12
oosik
Crowned tops sounds like a hay stacker not hay baler. Hesston & JD made stackers back in the 70's-80's.
   / hiring someone to make hay #13
I'm pretty sure that's illegal except in Nevada.
   / hiring someone to make hay #14
Tx Jim,
Those thumbnails are the same thing I saw him using. First time I ever saw anything like that. He was using it to put up very thick, heavy bottom land field grass.
   / hiring someone to make hay #15
I sold one of the JD model 200 stackers back when I worked for a JD dealer.
   / hiring someone to make hay #16
I guess I am lucky, going on the fourth year of a 50\50 split per field -- Orchard grass and clover. Small square bales.
I pick mine up by myself, and when he comes back for his I help him pick his up.
We just do the first cutting, I like to stockpile and usually don't need to feed hay till after New Years.
---------J
   / hiring someone to make hay #17
What's a reasonable price for someone to come in and make hay for you? bales will be 1000# round don't know if 4' or 5' wide. would they normally price on a per bale price?
I bet OSU has a custom rate structure for farming ops.
I charge on the MSU custom rate schedule on custom work. Even calculates fuel usage.
   / hiring someone to make hay #18
How much hay are we talking? 2 acres or 200 , makes a big difference
I won't bother with any custom work less than 5 acres. Too hard to turn equipment for one and just not financially worthwhile.
When I started out years ago, I cut anything, didn't matter if there were logs in the field but then I had a sickle bar mower conditioner. I own very expensive disc machines now, high end bailers and rotary rakes and I never take any job thats not mostly rectangular straight line running and is free of trash. I walk a customer's field first before I even think about pricing anything. If there is trash in there, it's see ya later...
Fot a couple acres of grief, I'd charge accordingly and probably a lot more than 55 a bale.
   / hiring someone to make hay #19
When I worked on a farm in the 80's he had a stack mover. It used the 3 pt to lift along with hydraulic powered wheels to lift. It had a set of tines on the bottom to lift. It was all a 4020 could do to move it. That w as for the 100 stacker. The 200 was twice as big and stacks had to be fed where they were unloaded. Too big to move.
   / hiring someone to make hay #20
Normally break it down
$16 - acre mowing
$12-acre raking
$6-7 per bale for baling
Some just prefer to pay $75/hour for the whole job
kids dirt bike (A56859)
kids dirt bike...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E50NKE58889, Extended Cab, 4 x 4, 5.0 L V8 Gas Engine, (A59076)
2022 Ford F-150 XL...
2014 Ford Fusion Passenger Car, VIN # 1FA6P0H77E5377755 (A56859)
2014 Ford Fusion...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2011 Peterbilt 365 Altec AC38-127S 5-Mast 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Truck (A56858)
2011 Peterbilt 365...
167 (A52708)
167 (A52708)
