Hinomoto N239 operating info
/ Hinomoto N239 operating info #1
classicfx
Newdigate
Hinomoto N239
Just purchased a used one of these privately in here in the UK.
I'm finding my way around things slowly (first tractor) but think I have a fault with the three point linkage. Problem is the the right hand linkage has an extra ram to adjust the arm independently which is fully up. This seems to be controlled by a double switch bank located on top of the right wheel arch, one switch controls the linkage up and down (works fine) the other switch seems to operate the ram up/down. In one position you can feel the ram operate up but in the other position nothing happens, ie the ram doesn't go down.
Am I doing something wrong? There's an array of switches and knobs by your right hand forearm but as everything's in Japanese it's difficult to understand operation.
Apologies if I'm being a muppet, but as said first tractor and a massive learning curve...... :confused:
/ Hinomoto N239 operating info #2
It is a draft contol. The 2nd from the bottom knob on the bank will adjust it somewhat but it will always move according to the terrain. I moved mine to the top link and removed the sensor.
Eugene
Thanks Eugene i'll have a go.
Remove the sensor from the ram ?
Thanks
Garry
/ Hinomoto N239 operating info #4
Yes
Eugene
/ Hinomoto N239 operating info #5
Yes
Eugene
Hi !
I also have a Hinomoto N239, and facing following problem. 3 point does not stay in position, it slowly keeps lifting all the way up. The only way to move it down is with engine off. Any idea what could cause this ?
/ Hinomoto N239 operating info #6
I bought my first tractor, N239, at an auction (UK), probably made in the 80s. The problem is that the three-point hitch is not working. I checked the hydraulic pressures, the internal wiring of the proportional valve control unit, the limit switches and the wiring of the valves and they seem to be fine. I can't get anything clear from the texts on the control switches in the cab, so I suspect I don't know how to use it. I would be very grateful for any hitch/tractor manuals or other tips on what might be wrong. Thank you.
2000 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2000 Freightliner...
UNUSED RAYTREE RMDB82-DIGGER HYD BACKHOE (A60432)
UNUSED RAYTREE...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
