Hinomoto N239 operating info
/ Hinomoto N239 operating info #1
classicfx
Newdigate
Hinomoto N239
Just purchased a used one of these privately in here in the UK.
I'm finding my way around things slowly (first tractor) but think I have a fault with the three point linkage. Problem is the the right hand linkage has an extra ram to adjust the arm independently which is fully up. This seems to be controlled by a double switch bank located on top of the right wheel arch, one switch controls the linkage up and down (works fine) the other switch seems to operate the ram up/down. In one position you can feel the ram operate up but in the other position nothing happens, ie the ram doesn't go down.
Am I doing something wrong? There's an array of switches and knobs by your right hand forearm but as everything's in Japanese it's difficult to understand operation.
Apologies if I'm being a muppet, but as said first tractor and a massive learning curve...... :confused:
/ Hinomoto N239 operating info #2
It is a draft contol. The 2nd from the bottom knob on the bank will adjust it somewhat but it will always move according to the terrain. I moved mine to the top link and removed the sensor.
Eugene
Thanks Eugene i'll have a go.
Remove the sensor from the ram ?
Thanks
Garry
/ Hinomoto N239 operating info #4
Yes
Eugene
/ Hinomoto N239 operating info #5
Yes
Eugene
Hi !
I also have a Hinomoto N239, and facing following problem. 3 point does not stay in position, it slowly keeps lifting all the way up. The only way to move it down is with engine off. Any idea what could cause this ?
/ Hinomoto N239 operating info #6
I bought my first tractor, N239, at an auction (UK), probably made in the 80s. The problem is that the three-point hitch is not working. I checked the hydraulic pressures, the internal wiring of the proportional valve control unit, the limit switches and the wiring of the valves and they seem to be fine. I can't get anything clear from the texts on the control switches in the cab, so I suspect I don't know how to use it. I would be very grateful for any hitch/tractor manuals or other tips on what might be wrong. Thank you.
2025 John Deere 3025E (A64126)
2025 John Deere...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
John Deere 4955 Tractor (A66285)
John Deere 4955...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
2023 FORD  TRANSIT T250 CARGO VAN (A59914)
2023 FORD TRANSIT...
