Hinomoto e204
/ Hinomoto e204 #1
az_rooster
can someone tell me how to remove the oil pan from the e204 the drive shaft seems to be in the way and do not know how to pull the drive shaft any idea or help
/ Hinomoto e204 #2
1 Set front of tractor on jack stands.
2 Remove the 3 bolts from the rear driveshaft housing.
3 Remove the 4 bolts from the front carrier bracket.
4 Remove the 2 bolts from the rear carrier bracket.
5 Drop the front axle down and roll forward.;)
Eugene
Formerly buppy69
/ Hinomoto e204 #3
You make it sound easy.
/ Hinomoto e204
got all that done but having a hard time to get the drive shaft an front axle to move
/ Hinomoto e204 #5
The splines on the shaft going into the transmission are probably stuck.May take some force.
Eugene
formerly buppy69
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
Misc. Pipe Lot 1 1/4", 2", and 3" Poly Pipe (A62679)
Misc. Pipe Lot 1...
2015 KENWORTH T800 TRI-AXLE (A65643)
2015 KENWORTH T800...
Melroe 5525 Skidloader Backhoe Attachment (A65640)
Melroe 5525...
