Hinomoto E-2304 Problems
   / Hinomoto E-2304 Problems #1
tsdial
Tennessee
Hinomoto 2304
Warning-this may be a long post.
I bought this Hino about 2 1/2 years ago. It's my first tractor, and I'll be the first to admit I knew nothing about them. I know a little more now-thanks to resources like this great group-but I've still got a long way to go. For instance, I didn't know you couldn't use ether-the guy at the place I bought it from (I guess it's one of those "roadside lots" you guys keep talking about) used ether on it when it was a little hard to start when he was showing it to me, so I thought that was okay to do. Shoot, the starter fluid I buy even said it's for diesels! Of course, after reading here, I know better now, but the damage is probably done. It's always been a little hard to start, so when it was cold I'd just give it a little shot to help it along. Always concerned me somewhat when I'd hear a bang or thud during the starting process, but I just assumed that was part of it.
Also, the tractor has a FEL on it, and I've worked it hard. Now I read on here that my model shouldn't have a FEL installed on it, that it might make the front end go out. Well, that may have happened also, as I'll describe later.
A week or so before Christmas I used the tractor with a subsoiler attached to it to break up some ground so we could dig a trench to lay some conduit in. I worked it pretty hard, as our soil here in Middle TN has a lot of clay in it. In the middle of doing this, it suddenly overheated. Turned out the belt broke this time, but it has overheated several times in the past, and I always wondered about it, as I was always careful to keep a good mix of antifreeze in it, and checked the level often. After hard use the level always seemed to go down-a lot of it was blowing out the overflow. I put a new radiator cap on it, sprayed out the fins in the radiator a lot, and when I was working in a dusty area I even put a furnace filter in front of the radiator to keep the dirt out of it, and changed the filter often (I'm in heating and A/C and had a bunch of scrap filter material to use). I thought maybe the water pump was going out. Now I believe that it's possible the head gasket is blown (which I actually had also wondered about).
Anyway, the tractor worked okay except for having to replace the belt. I got the new belt on, and finished what I was doing. It was probably a little over a week later when I used the tractor again, this time to push the dirt back in the ditch and to move and spread some gravel. While I was doing this I had headphones on and was listening to an MP3 player. In the middle of doing this, all of a sudden the tractor starts losing power and putting out black smoke, then quits. Since I had the music playing in my ears, I didn't really hear what it sounded like when it did this. The fuel gauge said 1/2 full, but I decided to fill it up anyway. Guess what? When I took the cap off the tank appeared to be dry (it was after dark and I couldn't see it very well, but it did indeed appear to be empty). I added fuel to it, and, knowing it probably wouldn't start, tried it anyway. Sure enough, no go. Since it was already 10 PM and I figured I was ticking the neighbors off anyway, I figured to let it go until the next day. Now I've gone through the pain of bleeding this thing once before, when I changed the fuel filter, and I know how hard it can be. I cracked the nuts at the top of the injectors and cranked it over until fuel started seeping out, then tightened them and tried again. Still no go. Had other holiday things to do, so I basically left it there until last weekend. Then my son and I used my truck to drag it to the garage. First thing we notice is the front wheels are dragging, not turning. I've got it in neutral, and I then pulled back on the 4WD lever to make sure it's disengaged. They still drag. I figure maybe I have to get it started and get the gears turning to totally disengage it. The drive is wet and the wheels are muddy, so we decide to drag it on over to the garage (when it quit it was only about 30 yards from the garage door anyway). While we are pulling it the rest of the way, one of the front wheels frees up. We get it close to the garage door and jack it up to put it on dollies to get it in the garage. When we jack up the front end, if we spun the free wheel, the other wheel turned also. ????
Got it into the garage, and have been tinkering with it a little here and there since then. Checked out the glow plugs, found 2 of 3 were dead. Ordered some, they came in today. Tried 'em, no luck. Since it had run dry and had put out all the black smoke, at one point I ended up pulling the injectors out, carefully taking them apart and cleaning them, and then put them back together and reinstalled them. Wouldn't start then, but I figured the dead glow plugs didn't help there.
While waiting for the plugs to come in, I ran across this forum and started reading. Stayed up 'til 11:30 last night reading, cutting, and pasting info into a word document. Today the plugs came in, but before I installed them I went to Harbor Freight and bought a cheap ($25) diesel compression tester. Another poster had said the pressure should be 398-454 PSI with a minimum of 327. Now I don't know how accurate this HF tester is-I know it's nothing like you professional diesel mechanics that post here use-but it showed the following; cylinder closet to steering wheel, 460 PSI, middle one, 240 PSI, the farthest front one, 260 PSI. I blew air in the middle cylinder and couldn't feel any coming out of the other two. I should also state that when I did this I was using the ports for the glow plugs, before I put the new ones in, so this might not be accurate-I guess the pressure might bleed back through the injectors, now that I think about it. What do you guys think? I just really didn't want to disturb the injectors again, and wasn't sure this kit had the right size fitting for them, whereas it did for the glow plug holes.
Anyway, I put in the new glow plugs and tried starting it. Nada. BTW, I've kept my automatic charger on the battery since this weekend. It periodically kicks on to keep the battery charged, so I don't think that's the problem, although I also read that a car battery, which is what this probably is, may not crank it fast enough. What kind of battery should it be? I replaced the starter earlier this year, so it should be working properly. I even pulled the rubber hose between the intake and the filter body off, and sprayed a little WD-40 down the intake; somebody here had suggested that to another person with a similar problem-I figured it was to increase compression. After spraying a little in, I then directed a heat gun to blow down the intake. When I cranked it over, nothing really happened at first, then about 25 or 30 seconds into cranking it would start to sound different, like it was about to catch, and then start putting out black smoke. It would do this for a few revolutions, then sound like nothing was happening, then for a few revolutions sound like it was about to start again. I was afraid to crank it very long-as it is, the starter overheated a couple of times and I had to let it cool off. Tried this a few times, then gave up and decided to come here and post. A couple of times when I was cranking it, it almost seemed like it was blowing smoke back out of the intake, like a valve was stuck open or something.
So, what's everybody's opinion(s). Blown head gasket? Stuck valve? Just haven't gotten the fuel system bled out properly? Somebody mentioned injection pump 180 degrees out of time on another, older thread. Can that happen w/o taking it off? Speaking of timing, how do you time this engine?
And the front end-think a gear's busted, as another poster had experienced, or do I just need to get it running again to get it out of 4WD? I kinda like this old tractor, but as everybody points out, Hino's are tough to get parts for. If it's going to take a lot to get this thing going right, I don't want to waste money on it. My wife is open to me getting a brand new tractor :eek: :D , and with all the 0% financing going on, I could see myself on a new one, a brand that parts are available for. I just hate to give up on this one if it can be fixed for a reasonable amount. But the chores are backing up-post holes need to be dug, dirt needs to be moved, gravel needs to be spread, and the drag harrow needs to be drug over the horse manure....:rolleyes:
Let me know what you guys think, and thanks in advance for any help you can give.
Tad
   / Hinomoto E-2304 Problems #2
Do the air test again on the 2 cylinders that are low and this time remove the radiator cap, look for bubbles in the coolent while the air is in the cylinder. I am guessing the headgasget has blown into the cooling passages, this is the source of your overheating, coolant issues and now a non start. The low compression on the 2 cylinders will cause the black smoke and not wanting to start. If you read back far enough in the archives, the was another Hino that died in the same fashion with the black smoke and then not wanting to start, and it was a blown head gasget. There is a guy in IL that posts here that can get some Hino parts, I am sure he will chime in or you can find him posting to other Hino problem posts. Mike
   / Hinomoto E-2304 Problems #3
Sounds like head gasket or broken rings in those 2 cylinders. Plus it still may not be bled good enough. You have to let the fuel run until you see no more bubbles. As far as the front axle, it shouldn't be dragging. Since you can jack it up and turn by hand, I'm hoping it was just in a bind when it shut off. Len Sheaffer is good at getting parts from Hitachi who now owns Hinomoto.
Eugene
Mike,
That sounds like a good suggestion and I'll try it. I had read back through most of the threads on Hinos and saw the one you mentioned-that's what lead me to believe that it might be a head gasket. What do you think of pressurizing through the glow plug ports? Could I be damaging the injectors? Would the air/compression pressures bleed back through the injectors?
Thanks for replying,
Tad
   / Hinomoto E-2304 Problems #5
A Hinomoto will not start with that low of compression on 2 cylinders. The good news is, if you had done any damage to the pistons with the either, you'd be getting a zero reading. I check compression through the glow plug holes,no problem. The reading you're getting off of #3 tells me your guage is working just fine. I've never put air pressure into the cylinders so I can't answer that one.
Eugene
   / Hinomoto E-2304 Problems #6
PS. I've put car batteries in every one I've ever owned.
Eugene
Eugene,
Good to hear that I probably haven't done in the pistons! Do you think I might've damaged the rings, though? What do you think made it happen all of a sudden like that? Been leaking some, got hot, and finally blew a big hole in head gasket?
Thanks,
Tad
Whoops! Sorry Eugene, I missed where you posted earlier that it might be the rings in those 2 cylinders. Sounds like I need to start taking this thing apart and looking inside, although I might try bleeding the fuel lines again. I'm also thinking about pulling off the tank and cleaning it out, and blowing out all the fuel lines, and replacing the filter. The fuel I had put in it after it quit was fresh, but God knows what else was in the tank at that point.
   / Hinomoto E-2304 Problems #9
I wouldnt mess with the fuel lines again, your getting fuel, the black smoke is evidence of that. Your problem is the low compression on those 2 cylinders. My money is on a blown headgasget and not rings. But your not gonna know till ya get that head off the block and see what you find. Take lots of digital pics as you take her appart, they will help when you put it back together again. Mike
Update-
I finally got the time this morning to pull the head off-sure enough, you're right, BotaMike. Appears to have been a hole in the head gasket between the middle and front cylinder, and it appears to maybe have been there awhile, although it's hard to tell. The whole head gasket was pretty mangled when I got it loose. I didn't see any scoring on the cylinder walls, and no holes in the pistons, so I felt pretty good about that. Now it's a matter of finding that head gasket. I e-mailed Mr. Sheaffer last week about one and some other parts, but I haven't heard back from him yet-I figure he's probably pretty busy and it takes some time to track this stuff down. In the meantime, just in case he can't get one, any suggestions?
Tad
(APPROX 22) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 22) 2" X...
(12) ROLLS OF WELDING WIRE (A51247)
(12) ROLLS OF...
1994 East Manufacturing Trailer, VIN # 1E1U1Y288RRC16516 (A51572)
1994 East...
JOHN DEERE 560M LOT NUMBER 37 (A53084)
JOHN DEERE 560M...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
Landoll Hauloll (A53472)
Landoll Hauloll...
