Hinomoto C174 drive problem
/ Hinomoto C174 drive problem #1
thedon737
My C174 is struggling to climb mild gradients and even on flat ground will not drive forward when put in HIGH range. It has a HydraStatic gearbox with just 3 ranges, High, Medium and Low. Even in Low range with the 4 in one loader and a carry all tray on the back but with no other load it cannot climb a very mild gradient that I feel it should be able to do.
Am I asking too much?
Thanks for any help!
/ Hinomoto C174 drive problem #2
Have you checked the trans fluid level and replaced the hydraulic filter?
Eugene
The fluid level is fine but I have not checked the filter. Could a dirty filter cause this problem?
/ Hinomoto C174 drive problem #4
</font><font color="blue" class="small">( Could a dirty filter cause this problem? )</font>
Yep.....If the fluid won't flow, your tractor won't go /forums/images/graemlins/shocked.gif
Have sent the tractor to the service workshop to check the filter and the gearbox oil.
Will see what happens. Thanks
The workshop tells me the head gasket was leaking and they are replacing it. They said this could cause the problem but I am sceptical.
The problem showed itself by not being able to climb mild gradients but the engine did not stall. The engine was revving fine it just seemed like the gearbox was slipping.
Any thoughts?
Thanks
/ Hinomoto C174 drive problem #7
I guess anything's possible. If the engine would't keep the RPM's up, the pump wouldn't be pumping to capacity and might cause the trans to slip. Let's just wait and see.
Eugene
Thanks
I am sceptical because I do not believe the engine was losing any power it just appears that the drive starts to slip and eventually the tractor just stops moving forward but the engine is still running hard.
Sounds more gearbox related to me so the filter is a possibility. Also does anyone know what is the grade of oil that has to be used in the gearbox?
Thanks
/ Hinomoto C174 drive problem #9
DO you have any pictures of your tractor. I am a fan of the Hinomotos and have never seen a hydrostatic grey market. I wonder why you don't see more? Hinomoto built tractors for Massey and Allis Chalmers and those Hino built tractors were available with a hydrostatic transmission.
/ Hinomoto C174 drive problem #10
I think that there is also a transmission screen besides the pickup screen.
/ Hinomoto C174 drive problem #11
Sounds like your workshop is just trying to make a few bucks and avoid your problem. Unless you are losing rpm's, the head gasket has nothing to do with your drive problem, if it really is leaking.
2008 Ford Expedition SUV (A61574)
2008 Ford...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
SQUARE FUEL TANK W/ HAND PUMP (A63291)
SQUARE FUEL TANK...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
