Hinged back, or regular back box blade
/ Hinged back, or regular back box blade #1
MinnesotaEric
Super Member
Nevis, MN
Kioti NX6010
Can somebody explain the virtues of a hinged back and fixed back box blade in so far as working goes?
Thanks everybody!
/ Hinged back, or regular back box blade #2
With a hinged back blade locked in place, there is no difference. With it unlocked, you can dig quicker, deeper at the start of each pass. And you can dig in a concave situation, which is sort of what you have right at the start of a pass.
I was sloping a hillside and couldn't dig at the bottom of the slope with a fixed blade box blade--had to switch to the rear blade to get the "corner." As soon as the tractor front wheels hit the flat ground, the front blade stopped cutting as the contact shifted to the rear blade. I wanted the slope to meet the flat at an angle. What I got was a long, gentle curve.
Bruce
/ Hinged back, or regular back box blade #3
I agree with bcp. I'm no box blade expert, but my experience is just what he said. My box blade will really dig in quickly and move lots of material with the back unhinged.
With it locked in the fixed position, it works better for general grading type work.
One other "virtue" is that most hinged back box blades seem to be heavier built than the typical fixed ones. Most of the light duty box blades don't offer a hinged back. So when you see one with a hinged back the chances are that it's at least a medium duty one.
/ Hinged back, or regular back box blade #4
What they said, we have both kinds and for serious dirt work, we prefer the hinged back. The others work well, hinged back just better for some things.
Insofar as I've understood, the hinged back is better in the sense that it allows the front blade to dig in more aggressively because the hinge allows the rear blade to fold out of the way.
Next question:
Is a Howse CAT2 84" hinged box blade good enough, or should I look into a Woods/Gannon 80LB or is there another brand that I should consider?
/ Hinged back, or regular back box blade #6
Hydraulic?
Don't know about hawse but my 78" 4x2 HB Gannon is built like a tank.
/ Hinged back, or regular back box blade #7
Hit submitit too soon.
What are the weight differences?
Weight on either isn't an issue for my tractor, but the Howse BEB84 84" hinged back is a medium duty box blade and weighs 620ish pounds.
The unfair comparison is with the Woods/Gannon 80LB which is significantly better built and weighs over 1000 pounds.
I can get the Howse for less than a grand, and I have no idea how much more the Gannon would be.
/ Hinged back, or regular back box blade #9
Question wasn't focused at how much you can pull. The heavier the box blade the better it works.. I would vote for the heavier box blade everyday of the week and twice on Sunday...
Brace yourself when pricing the Gannon.... But there's a reason for it. If you're getting hydraulic rippers better be sitting down when u price it.. I was lucky and found mine on Craigslist.
/ Hinged back, or regular back box blade #10
That Gannon will probably be in the neighborhood of $3,500. I found my old beat up war horse Gannon for $1,100, and spent about $150 getting the cylinder rebuilt and replacing the hoses on it. After using it for most of the last year, I can say it was well worth the cost.
/ Hinged back, or regular back box blade #11
I have a 60" Howse hinged box blade for our smaller tractor, and Howse makes a nice product. But if you're looking at their BEB84 medium duty blade for your NX6010, I'd sure at least look at the Woods BSM84 as an alternative. Not hinged, but it's 130 lbs heavier at 750 lbs and exceptionally well made. Mine was around $1350 a few months ago. I love it. As between hinged and non-hinged, once the scarifiers are down, I haven't seen a lot of difference in ability to dig as between my 60" box blades. They'll both tear up the dirt pretty quick. My first 60" bb was non-hinged, and if I had it to do over again, my 60" Howse would be as well. The blade doesn't lock, and it seems harder to grade in reverse with it, although I'm not sure why.
I haven't kicked the tires of a Woods 80LB, but from the specs it's in a whole 'nuther league. Much heavier, with hydraulic scarifiers. Very sweet, if you can justify it in your budget!
/ Hinged back, or regular back box blade #12
they only make one kind of box blade Gannon
/ Hinged back, or regular back box blade #13
. . . My first 60" bb was non-hinged, and if I had it to do over again, my 60" Howse would be as well. The blade doesn't lock, and it seems harder to grade in reverse with it, although I'm not sure why. . . .
Well, that shows how little I know. I didn't know that some hinged models couldn't be locked.
Decorative Pelican Statue (A61569)
Decorative Pelican...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2021 Hamm Compactor HD 70i VV Asphalt Roller (A61166)
2021 Hamm...
2016 KUBOTA SVL75-2 (A64047)
2016 KUBOTA...
TAKEUCHI TS50R SKID STEER (A62129)
TAKEUCHI TS50R...
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
