High pitched whine
/ High pitched whine #1
Scooterman
I have a 7610 and when moving the tractor forward in high range I get this high pitched whine and the faster I move the louder it gets. This happens on the level with no load on the tractor. The noise sounds like it's coming from the front of the tractor. Happens in 2 or 4 wheel drive. Fluid levels are ok any thing else I can check?
/ High pitched whine #2
You didn't perhaps set the parking brake and forget to release it did you?
/ High pitched whine #3
Parking brake or wet or loose V belt, No you dont use belt dressing!!!!!
Least possible is air bubbles in the coolant and a worn cooling pump.
/ High pitched whine #5
Have you greased all parts after this very taxing winter.
Everything is greased. This noise started last fall while mowing. Tractor has 260 hrs on it. I keep it serviced.
/ High pitched whine #7
My first post. My 3030 with 200 hrs makes a squeeling noise , only in high range going down the road. Never while in medium range. If I let off the throttle it stops. But starts back up when I put the throttle back down. It seems RPM dependent. If I keep the RPMs at 1,100 - 1,200 it seems to go away. My dealer said bring it in , but right now I am busy cutting wood and don't want to give it up.
/ High pitched whine #8
does it sound like it is coming from the left front? My 7510 would make a noise like that and I think it was coming from the alternator I had thought it was the hydro pump but that is on the other side of the engine.
Rob
John Deere 530 MoCo (A66408)
John Deere 530...
2003 MACK CV713 KILL TRUCK (INOPERABLE) (A65643)
2003 MACK CV713...
FORD 4610 TRACTOR (A64277)
FORD 4610 TRACTOR...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
Sudenga 10 x 63 Portable Swing-away Auger (A66408)
Sudenga 10 x 63...
