Tires High Flotation Fronts
   / High Flotation Fronts #1
CTPhil
NW CT
I'm going to need new front tires on my 2WD Ford Industrial, and would ideally like to have more ag type tires. I could go 3 rib, but am not crazy about how they tear up turf. 4 rib fronts offer the vague promise of "flotation". I often have to feed out round bales in extremely muddy conditions, so my thoughts are drifting in that direction.
Years ago I had use of a neighbors IH 684, it had pretty wide implement type front tires. I couldn't help but notice that the front end didn't sink in when I was haying on wetland fields. So I'm wondering about getting 8 inch or wider rims and going in that direction.
Any thoughts would be appreciated. :)
   / High Flotation Fronts #2
My brother uses truck tires on the front of his Ford.
That's the cheapest option, assuming used, but I'd like to at least entertain the notion that there may be a better way to go. (assuming I can afford it). :)
   / High Flotation Fronts #4
Yes, they are used, we all drive trucks from 1/2 to ton, so good used tires are no problem.
I'm actually having problems locating used truck tires here. (7.50x16)
   / High Flotation Fronts #6
check out the local recycle center....... people bring old wheels and tires there all the time. even junk tires are fine, if you install tubes.
my tractors are both 4wd so I have to stick with properly sized AGs. I hade an old case 2wd and that had what ever we found laying around in the tire pile on it.
   / High Flotation Fronts #7
I never liked using the truck tires especially worn smooth tires on the front end as it didnt steer well in the mud without brake steering. They just tend to slide sideways and plow a furrow rather than turning the tractor. I preferred the 3 rib design or even 4 rib in as wide as possible 10:00 x whatever your rim diameter will give excellent flotation and due to the width, give less ground pressure to avoid tearing up the ground so bad. Some of the 4 rib trailer tires (9:00x16) would likely work well also.
   / High Flotation Fronts #8
We don't wear tires even close to smooth on any of our trucks. I have 32k on mine and am replacing them this month. A couple of family members are really picky about tires too, so we have plenty to choose from in 16" and even some 17". My son in law has a tire dealership in the family and they sell good take offs reasonably priced.
We just use our Fords for bush hogging and turf/ground damage is less than with ribbed tires. When we farmed with them, we used the ribbed tires.
   / High Flotation Fronts #9
I use BF Goodrich Radial Long Trail Load Range R LT 245 / 75R16 on my tractor. They are 10 ply tires that are rated for 3040 lbs at 80 psi.
The tractor I need tires for is new to me, and needed kingpin repair before I used it. I did the repair and tried the loader, moving manure on the level but with a muddy surface. The existing truck tires (good tread but sidewalls falling to pieces) were no less than worthless steering in the mud. Since a lot of my loader stuff is under similar conditions, I need to move on to considering other options. I don't want to give up on increased flotation, I'm wondering about wide (11L) tri-rib fronts. Any thoughts?
UNUSED MOWERKING SSECAG-Y AUGER BITS (A51244)
UNUSED MOWERKING...
Barn Wood Picnic Table (A50515)
Barn Wood Picnic...
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
