Hickory Logs; What to do with them?
/ Hickory Logs; What to do with them? #21
Deere, If you have ants in the log, they may tell you to get the heck out right now because they don't want the ants in the mill. The others are a little to small for them to deal with. If you had a bandsaw in your shop, you might be able to saw some boards out of them, just cut them in 3-4 ft lengths and cut a couple of boards off. Sticker them, with weights on top, and let them dry for a year per inch. Also wax the ends to keep splitting down.
/ Hickory Logs; What to do with them? #22
I dont think your going to lift a 12" diameter 10ft long hickory log onto your bandsaw!!
/ Hickory Logs; What to do with them? #23
Clemsonfor, I was talking about the 6 inch logs on the bandsaw. I resaw on my bandsaw up to 11 3/4 inches. I have a couple of jigs that I screw into the log, and then run them against a fence on the table. It is not rocket science, 3-4 feet at 10 inches can be managed if your bandsaw, has the capacity. Might want to have a friend to help lift the log into place.
/ Hickory Logs; What to do with them? #24
If they have ants you can still trade or sell them to a guy that smokes bbq. Over the course of about a year I traded a huge oak downed by hurricane Ike with a pro smoker, wood for meat. Mmmmm, bbq.
/ Hickory Logs; What to do with them? #25
If you don't have many logs to saw it wouldn't be worth taking them to a mill, cost wise anyways. Unless your emotionally attached to these former trees then just use them for firewood. Now, if you had posted this 3 yrs ago when they were still green, I would say to leave them log length that you have, and call someone with a portable sawmill to mill them. You don't want logs laying around for long until you mill them. Hickory is a whole lot better than pine in that regard but overall, you want to mill them green. Then of course, rule of thumb for hardwood is one inch per year when properly stacked and stickered.
Logs sitting around for 3 yrs aren't going to be worth it. There is no need to cut them to 8'6" unless you want dimensional lumber. I mill most of my logs much longer, but I'm using them for timber framing projects and not to build a shed. If in the future you find some trees that would make some nice logs, it's best to find a sawmill beforehand, then ask them what they would like you to cut the logs to, then take the tree down.
Also, not all lumber has to be perfectly straight, you can make some very interesting pieces of furniture with crotched or crooked lumber.
Thanks for all the input and good ideas folks. What started out for me as a good idea turned to crap real fast. I just wish I would have considered milling them when I cut them down, I would have done things a whole lot different. It's to late to cry over spilled milk. Next time I will be a little more diligent when cutting the tree down and getting it to the mill.
Chuck
/ Hickory Logs; What to do with them? #28
Chuck
On the bright side, it's the best firewood you can get!
/ Hickory Logs; What to do with them? #29
The inner bark of a hickory is the best for weaving into chair seats. Lots of work but will last longer than you do.
/ Hickory Logs; What to do with them? #30
Chuck
Might make good B-B-Q smoking wood. Save the chips when you cut it.
One thing to consider next time ( for you or other members) see if there is a portable mill around. They can come right to the site. If they come out for a site check and bid before you drop the trees they can give you some great advise.
My brother bought one as a part time job and to build a barn/shop using the trees off his 15 acres. If you work with the miller and use your tractor to skid logs to and onto the mill you should get a break on cost. And, you get the wood cut to your specs. If you have excess wood you might be able to barter if the miller has a market for the wood.
Good luck and best wishes.
Okay, I have a few medium sized logs that I think will be fine for a mill. In the meantime, my neighbor just cut down an oak tree about 28" in diameter and the trunk is pretty straight for about 20+ feet or so. I don't know what kind of oak it is. If I was going to guess I would say red oak, but not sure. I plan on switching some of my hickory logs I have for the equivalent oak trunk I would take from him. He was just going to burn it in the fireplace anyway so it works for him.
The question is, this is not clear with no branches. There are 4-6" branch stubs off the side every few feet. Will that matter in the overall look of the oak. I usually just go down to the store and get clear oak and never milled anything so I am not sure what to expect. Will the branch stubs matter.
I am not a perfectionist when it comes to building stuff out of oak, but I do build some nice cabinets and whatnot.
I am still going to try to mill a couple hickory logs.
Chuck
/ Hickory Logs; What to do with them? #32
The knots will show in the boards, but can be an asset depending how you work the boards into your project. And will get smaller the closer you get to the center of the log. Just hope for tight knots after the air dry.
/ Hickory Logs; What to do with them? #33
4-6" are large for any type of furniture. Of the sawyer knows what he is doing he can minimize the effects of the stress in the log and the
Placement of the knots. A 28" oak that long is going to be extremely heavy.
I am just wrapping up switching them for some hickory. Trading cubic feet for cubic feet sucked most of my pile down, but at least these are just cut. I got 11' and a 12' approx. logs, and they are super heavy. One I could only lift a couple inches and the other less than that. I'm counting on the mill to do what is right with them.
2023 KUBOTA SVL97-2 SKID STEER (A65053)
2023 KUBOTA...
2017 Ford Explorer SUV (A64557)
2017 Ford Explorer...
2020 Inifiniti Q 50 Sedan (A64557)
2020 Inifiniti Q...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
46197SFL (A64557)
46197SFL (A64557)
