Hi.
phoenix 1
Irom county, Mo.
Kubota L3800
Hi, my name is Jerry.
I am the maint. supervisor at a meditation center in SE Mo. I found this site while looking for infomation on a beaver III tractor that has not been started for 1 1/2 years. They had me convinced that it was not worth using. I did use it winter before last to try and clear snow off the roads with limited success. ( this was the first CT that I had used. turf tires, no chains, not much weight on the front). It went every where but where I wanted it to.:) They want to sell it and asked me to see if I could get it to run. so I found this group and through reading for a couple of days I have learned some of what I was doing wrong. Now I want to get it working properly and get some use out of it.
Go to the MAIN INDEX at the top this page, scroll down to Tractor makes and models, and look for Mitsubishi. You may find what you need there. Good luck.:welcome::tractor:
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63118)
2023 Kubota...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
250 GALLON FUEL TANK W/HAND PUMP (A62131)
250 GALLON FUEL...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
