Hi Sure could use some help on my 8N Tractor
   / Hi Sure could use some help on my 8N Tractor
If the ign switch is not supplying power to the points what should I do?
Thanks
   / Hi Sure could use some help on my 8N Tractor #12
You could by pass the key switch and fit a simple toggle switch to the ignition.
Mind that the starter motor still needs it's juice.
   / Hi Sure could use some help on my 8N Tractor #13
On the back of the ign switch you have diff positions no 1,2,3 and 4 .....1 is bat power ........2 is ign...........3 is thermostart............4 is for starting ........wile cranking 1 , 2 and 4 shoud have power on them . releasing the key 1 and 2 shoud have power on them.That is if a altenator has being fitted . If you still have a generator on your tractor , only 1,2 and 3 on the back of the switch .1 is power from bat ....2 fot thermostart and 3 for starting !
   / Hi Sure could use some help on my 8N Tractor #14
Welcome to TractorByNet!
I moved your thread to the Ford Vintage Tractors forum. :)
   / Hi Sure could use some help on my 8N Tractor #15
Thanks
You need to have 12v to the positive (+) side of the coil. The negative side (-) goes to the points.
It'll work in either direction but problems arise if wired backwards.
But you must have one way or the other 12v to one side (+) of the ignition coil.
   / Hi Sure could use some help on my 8N Tractor #16
any progress with hotwireing for a test?
   / Hi Sure could use some help on my 8N Tractor #17
Don't go confusing the OP, the N's key ignition is a 2 wire job, off and on, none of this 1,2,3,4 position stuff.
Show Livestock Tie Up Rack (A50515)
Show Livestock Tie...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2016 POLARIS RANGER ETX EFI 00HC RTV (A51243)
2016 POLARIS...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
