Hi Sure could use some help on my 8N Tractor
   / Hi Sure could use some help on my 8N Tractor
If the ign switch is not supplying power to the points what should I do?
Thanks
   / Hi Sure could use some help on my 8N Tractor #12
You could by pass the key switch and fit a simple toggle switch to the ignition.
Mind that the starter motor still needs it's juice.
   / Hi Sure could use some help on my 8N Tractor #13
On the back of the ign switch you have diff positions no 1,2,3 and 4 .....1 is bat power ........2 is ign...........3 is thermostart............4 is for starting ........wile cranking 1 , 2 and 4 shoud have power on them . releasing the key 1 and 2 shoud have power on them.That is if a altenator has being fitted . If you still have a generator on your tractor , only 1,2 and 3 on the back of the switch .1 is power from bat ....2 fot thermostart and 3 for starting !
   / Hi Sure could use some help on my 8N Tractor #14
Welcome to TractorByNet!
I moved your thread to the Ford Vintage Tractors forum. :)
   / Hi Sure could use some help on my 8N Tractor #15
Thanks
You need to have 12v to the positive (+) side of the coil. The negative side (-) goes to the points.
It'll work in either direction but problems arise if wired backwards.
But you must have one way or the other 12v to one side (+) of the ignition coil.
   / Hi Sure could use some help on my 8N Tractor #16
any progress with hotwireing for a test?
   / Hi Sure could use some help on my 8N Tractor #17
Don't go confusing the OP, the N's key ignition is a 2 wire job, off and on, none of this 1,2,3,4 position stuff.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2005 MACK GRANITE GU713 DAY CAB (A51222)
2005 MACK GRANITE...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2013 TIGER CAT 720E WHEEL FELLER BUNCHER (A51242)
2013 TIGER CAT...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52128)
2018 Dodge Ram...
