Hi my name is Hammick and I'm an over-greaser
   / Hi my name is Hammick and I'm an over-greaser #31
The ultimate greaser approves.
   / Hi my name is Hammick and I'm an over-greaser #32
One pin on the left lift cylinder was dry:eek: It would slide side to side but thankfully had no radial play.
Some how I had never greased that zerk because of its angle it was difficult to get the grease gun to stay attached[no locknlube].
I did manage to pump it full which tightened it right up.
In my biased opinion (as usual), the Lock and Lube grease gun greaser is a total waste of money. Never had one, don't ever plan on getting one either. Quality grease gun ends all have a 2 piece barrel and the end is adjustable for jaw grab so if you put it on and it don't want to come off easily, you just rotate the end barrel a bit to the left and it will release.
Should be named 'Lock n boob' 'cause it's for ***** to use.:laughing:
   / Hi my name is Hammick and I'm an over-greaser #34
Yes, and along those lines, screw typing! I prefer to use a quill made from a goose feather, dipping it into a bottle of ink...gives me time to collect my thoughts. Actually, that's how I just posted this.
   / Hi my name is Hammick and I'm an over-greaser #35
Biased opinion based on zero experience. 🤣🤣🤣🤣.
   / Hi my name is Hammick and I'm an over-greaser #36
Well, lets see now, never seen one, never used one, think they are a waste of money, and only "*****" use them.... That about covers all the bases. :) I wonder what would happen if he was given one to use, and what if he liked it? (gasp!) What then? Would he then be a "boob" like us? :rolleyes:
   / Hi my name is Hammick and I'm an over-greaser #37
I've been greasing equipment for 30 years, the Lock n Lube is by a long shot the most useful grease attachment I've ever used.
   / Hi my name is Hammick and I'm an over-greaser #38
Don't want one, don't need one. Simple answer. Like the grease fitting rejuvenator. Don't need one of those either. My Alemite fittings don't clog up because I don't use cheap clay based grease that hardens in the fittings.
Maybe my choice of words was a bit harsh but then I realize that people today have extremely thin skins and get 'butt hurt' easily so I retract that comment.
Use whatever blows your dress up and I'll use what I deem necessary. Hows that?
   / Hi my name is Hammick and I'm an over-greaser #39
Sounds good. Wish I had the money to send you one., You would continue using it, I bet you would. . :) Seeing is believing. At least in most cases.
   / Hi my name is Hammick and I'm an over-greaser #40
You keep your money and the device. I'm all good with what I have. Thanks.
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2021 CATERPILLAR 289D3 SKID STEER (A52707)
2021 CATERPILLAR...
2005 Dodge Ram 4x4 Crew Cab Pickup Truck (A55852)
2005 Dodge Ram 4x4...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2015 Komatsu PC138 (A47477)
2015 Komatsu PC138...
