Hi my name is Hammick and I'm an over-greaser
   / Hi my name is Hammick and I'm an over-greaser #31
The ultimate greaser approves.
   / Hi my name is Hammick and I'm an over-greaser #32
One pin on the left lift cylinder was dry:eek: It would slide side to side but thankfully had no radial play.
Some how I had never greased that zerk because of its angle it was difficult to get the grease gun to stay attached[no locknlube].
I did manage to pump it full which tightened it right up.
In my biased opinion (as usual), the Lock and Lube grease gun greaser is a total waste of money. Never had one, don't ever plan on getting one either. Quality grease gun ends all have a 2 piece barrel and the end is adjustable for jaw grab so if you put it on and it don't want to come off easily, you just rotate the end barrel a bit to the left and it will release.
Should be named 'Lock n boob' 'cause it's for ***** to use.:laughing:
   / Hi my name is Hammick and I'm an over-greaser #34
Yes, and along those lines, screw typing! I prefer to use a quill made from a goose feather, dipping it into a bottle of ink...gives me time to collect my thoughts. Actually, that's how I just posted this.
   / Hi my name is Hammick and I'm an over-greaser #35
Biased opinion based on zero experience. 🤣🤣🤣🤣.
   / Hi my name is Hammick and I'm an over-greaser #36
Well, lets see now, never seen one, never used one, think they are a waste of money, and only "*****" use them.... That about covers all the bases. :) I wonder what would happen if he was given one to use, and what if he liked it? (gasp!) What then? Would he then be a "boob" like us? :rolleyes:
   / Hi my name is Hammick and I'm an over-greaser #37
I've been greasing equipment for 30 years, the Lock n Lube is by a long shot the most useful grease attachment I've ever used.
   / Hi my name is Hammick and I'm an over-greaser #38
Don't want one, don't need one. Simple answer. Like the grease fitting rejuvenator. Don't need one of those either. My Alemite fittings don't clog up because I don't use cheap clay based grease that hardens in the fittings.
Maybe my choice of words was a bit harsh but then I realize that people today have extremely thin skins and get 'butt hurt' easily so I retract that comment.
Use whatever blows your dress up and I'll use what I deem necessary. Hows that?
   / Hi my name is Hammick and I'm an over-greaser #39
Sounds good. Wish I had the money to send you one., You would continue using it, I bet you would. . :) Seeing is believing. At least in most cases.
   / Hi my name is Hammick and I'm an over-greaser #40
You keep your money and the device. I'm all good with what I have. Thanks.
2019 CATERPILLAR 242D SKID STEER (A52707)
2019 CATERPILLAR...
2016 Chevrolet Suburban SUV (A55853)
2016 Chevrolet...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2008 Ford F-150 Ext. Cab Pickup Truck (A55852)
2008 Ford F-150...
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
