hi i'm new to this forum
   / hi i'm new to this forum #1
terryekdahl
John Deere 2120
Hi I own a JD 2120 which i am wanting to replace. Looking at a 2wd 2350 with 240 loader. Anybody have opinions on this tractor?
   / hi i'm new to this forum #2
Welcome to TBN. :)
   / hi i'm new to this forum #3
There is a John Deere forum here on TBN. Perhaps you might get more replies by posting in the John Deere forum. Good Luck. Welcome aboard. :tractor:
   / hi i'm new to this forum #5
WELCOME to TBN :)
I moved your thread to the John Deere Buying/Pricing Forum.
   / hi i'm new to this forum #6
Big stout loader! Have a neighbor with one.
Several folk's have commented that the 50 series is a better tractor than the 40 series utility model's.
I wished I had a good shape 40's... so, the 50 would be another step up!
That said - have not read many comment's regarding serious issues with them. So, like buying anything used... much depends upon how it was maintained and worked.
AKfish
   / hi i'm new to this forum #8
Welcome! If the 240 loader is anything like the 245 loader, very HD loader. Probably overkill for that tractor.
   / hi i'm new to this forum #9
Ooops.. I meant 245 loader. Well, they've gotta be fairly close in dimensions and capability!
AKfish
   / hi i'm new to this forum #10
Great tractor, we have a 2550 which is one size larger and it has been basically trouble free for 25 years now.
There are a few minor issues that these tractors have, but are mostly related to age (seals, gaskets, hoses, etc). Some of the more notable ones to look for are leaks around where the lower 3pt hitch arms attach to the rear axle (draft sensing rod), the hyd. pump case drain line, leaks around the bottom of the steering column, and internal leaks in either the power-reverser or hi-lo power shift if so equipped. Aside from the latter two, those are all pretty easy to fix and not very expensive. If it does have a power-reverser transmission or hi-lo power shift be sure to work the tractor until it gets good and warm and make sure both are still properly functioning.
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2015 Mack GU813 Mixer Concrete Truck, VIN # 1M2AX13C0FM028499 (A51572)
2015 Mack GU813...
2023 GMC 3500 Bed (A51573)
2023 GMC 3500 Bed...
2002 Kenworth T800 Truck, VIN # 1XKDD49X72J898126 (A51572)
2002 Kenworth T800...
