Hi from ohio
/ Hi from ohio #1
R1campr
Harrison, ohio
Husqvarna
New member here. Im turning our old horse pasture back to a lawn and need to get a garden tractor to mow with. I ran across this site looking for info on garden tractors, never had one before. A lot of great info on this site, thanks everyone for your time to post and built a wealth of info for us newbies to tractors. Hopefully i make the right decision on what tractor will fit my needs.
/ Hi from ohio #2
:welcome: you near medina?
/ Hi from ohio #3
Welcome - give us some details of what you are looking, for, budget and such and we can give you some ideas.
/ Hi from ohio
Murph , other end of ohio, near cincinnati. Ibeen trying to learn all i can about garden tractors, and am leaning towards a husqvarna gt48 or 52 xls. My land is hilly, probably 25-30 degree max on parts of 2 acres that will be mowed. So larger tires with differential lock would probably be good. I also would like to use it for grading parts of it after having my neighbor run a disc harrow over it with his atv. Horses made a real mess of it. I also want to use it for grading loose gravel now and then for paths in the woods and parts of driveway. Ive read the husq gt's have a stronger transaxle than all the lawn tractors you see at lowes and hd. I'll prob be spendin around 4k with a few attachments and a sleeve hitch.thats probably the max of what id want to spend.
Theres one Husqvarna authorized service place near here, but he doesnt stock or sell them. So, i have a place for service, warranty if i cant tackle it myself. I think his shop can order one for me, but i havent talked with him yet, or got a price on one from him. Dont know if he can get me a better price than buying one online and having it delivered.
Has anyone here bought a garden tractor from one of those online shops?
/ Hi from ohio #5
:welcome: from Texas!
/ Hi from ohio #7
I would buy a used 2 wheel drive utility like my MF-135 or JD820 or 830 something like that.
/ Hi from ohio #8
Welcome from NW Florida, R1.
I have the YTH 24 HP 48" Husqvarna. It is a good mower, but if you need anything but mowing, you will need to get a SCUT or CUT. {sub-compact utility tractor/compact utility tractor} My mower lists for $1.9K, but I got it with 32 hours on it for $900. The GT28 has a 27 HP engine. As much as mine drinks gas, I'm betting this one is even worse.
The GT 48 lists for $3.4K. For a little more you can buy a good used tractor with a RFM. {rear finish mower} You will soon save enough on fuel to pay for the difference. Plus the tractor can be used for a hundred other things a mower can't be used for. And 2 acres is right on {or over} the edge of a riding mower's sweet spot.
I couldn't find the 55 online, but looking at the GT 48, I didn't see any kind of hitch on it. Does it have a lift of some sort, or just a hole for a pin?
/ Hi from ohio
The gt's (garden tractors) have a hole for a pin on the back, they sell the sleeve hitch separetly. It all bolts to the plate on the back, giving it a manual lift for accessories. I saw somewhere online theres a bracket for the back that has a hook, pin hole, and place for a hitch ball, but i think it only bolts to where the original pin hole is, not sure if that would be strong enough for pulling accessories. I think the sleeve hitch also fits on the front.
I found a dealer about 30 miles away that has the gt 52xls, will check it out next week.
Is a garden tractor considered a scut? Since it is a ground contacting tractor?
2012 Range Rover SUV (A61569)
2012 Range Rover...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
New Holland 3930 (A60462)
New Holland 3930...
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
