Hi-Flow Hydraulics
   / Hi-Flow Hydraulics #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
Is there anything wrong with running a standard flow attachment with the hi-flow circuit IF the attachment specs are within machines hi-flow flow and pressure? Some attachments just say Minimum Flow 13 GPM in the spec. So could this attachment run off either std. or hi-flow circuit?
   / Hi-Flow Hydraulics #2
NO, as long as you don't apply more GPM and therefore up the rpm of the hyd motor beyond the rated rpm limit.
Some attachments are designed for high flow, and must have the minimums to operate satisfactory.
Most hyd tool will operate at about any flow, but may not provide satisfactory results.
   / Hi-Flow Hydraulics #3
Agreed.
SET OF SKID STEER QUICK ATTACH PALLET FORKS (A51242)
SET OF SKID STEER...
NAMCO GRAIN-O-VATOR GRAIN WAGON (A51243)
NAMCO...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
Lot (3) Rolls of Barbed Wire (A50515)
Lot (3) Rolls of...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
