Hew Holland 678 Round Baler
   / Hew Holland 678 Round Baler #1
mandrews9
New Holland T4.100
Round baler does not put all of the hay from the pick-up into the chamber! I end up with a bunch of hay piled in between the chamber and the string box. What is causing this and what can I do to fix this issue?
   / Hew Holland 678 Round Baler #2
Welcome to TBN
What size are the windrows? Have you tried operating baler at a little lower than recommended pto rpm's? What type of hay & is hay too dry?
Welcome to TBN
It was grass hay but small thin windrows. I haven't tried a lower rpm.
   / Hew Holland 678 Round Baler #4
If as you state windrows are thin & rpm's are kept at 540 hay falls off forming bale about as fast as it's being applied. One needs to slow rpm's & shift up a gear or 2. BTDT
   / Hew Holland 678 Round Baler #5
are you weaving over the windrow?
1991 CHEVORLET 2000GAL WATER TRUCK (INOPERABLE) (A58214)
1991 CHEVORLET...
CFG Industry QH12R Mini Excavator (A57149)
CFG Industry QH12R...
2385 (A58376)
2385 (A58376)
2011 TROXELL 130BBL STEEL (A58214)
2011 TROXELL...
2344 (A58376)
2344 (A58376)
2186 (A58376)
2186 (A58376)
