Hew Holland 678 Round Baler
   / Hew Holland 678 Round Baler #1
mandrews9
New Holland T4.100
Round baler does not put all of the hay from the pick-up into the chamber! I end up with a bunch of hay piled in between the chamber and the string box. What is causing this and what can I do to fix this issue?
   / Hew Holland 678 Round Baler #2
Welcome to TBN
What size are the windrows? Have you tried operating baler at a little lower than recommended pto rpm's? What type of hay & is hay too dry?
Welcome to TBN
It was grass hay but small thin windrows. I haven't tried a lower rpm.
   / Hew Holland 678 Round Baler #4
If as you state windrows are thin & rpm's are kept at 540 hay falls off forming bale about as fast as it's being applied. One needs to slow rpm's & shift up a gear or 2. BTDT
   / Hew Holland 678 Round Baler #5
are you weaving over the windrow?
HIGH-END MINI GOLF CART (A55745)
HIGH-END MINI GOLF...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
2017 FORD F-350 SUPER DUTY (A55745)
2017 FORD F-350...
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
Mobile toilet (A53424)
