Heres one for you...
/ Heres one for you... #22
Dad built an F-20 Farmall w/a 327 Chevy and powerglide hooked to original trans.
It would disk ground at 30 Mph.
<font color=red>Dad built an F-20 Farmall w/a 327 Chevy and powerglide hooked to original trans.
It would disk ground at 30 Mph. </font color=red>
When I was a kid, my dad picked up an old Cat dozer for the back hoe on it. Some one had swapped in a 307ci Chevy motor. Ran good, but always hot, and just did not have the tourke it should have.
<font color=red>http://home.att.net/~jmsmith45/optmisc.htm
There is a few "updated" N series tractors here</font color=red>
Ohh!! I like that 351 powerd one. Hay, I have a few of those motors sitting around.hmm/w3tcompact/icons/hmm.gif
/ Heres one for you... #26
3 PAGES WOULD BE A LLOOONNNNGGGGG THREAD.
/ Heres one for you... #28
now ya have me thinkin..rotflmao...no really was trying to figgure a way to replace the mag on the Case,one of the lobes are worn...$350.00 for a rebuilt.think i can adapt a electronic ign out of maybe a GM 4 cyl...hummmmm cut the head about .30 ....work the cam over with the grinder...flip the intake and adapt a webber. guess tractors are like Jeeps and Harleys...real ones are built not bought..... Sid
THATS what I'm talking about. Anyone can sign there name and buy one. It takes a true wacko to build there own./w3tcompact/icons/smile.gif/w3tcompact/icons/grin.gif
/ Heres one for you... #30
Nitro is a type of liquid fuel
Nitrous (short for nitrous oxide) is an oxygen bearing gas.
If you use electronic fuel injection, where do you fit the pump? Is there enough room for one in a tractor fuel tank?
/ Heres one for you... #31
ie:laughing gas...commonley used in denistry....throttle body fi just uses a transfer pump.multi port must use a transfer and also a pressure pump.nitrious uses bottle pressure that is porportioned through a regulator....Sid
<font color=red>If you use electronic fuel injection, where do you fit the pump? Is there enough room for one in a tractor fuel tank? </font color=red>
They make retro fit highPSI fuel pumps now, that mount inline. No need to fab an intank setup. Lots of good stuff out there these days./w3tcompact/icons/smile.gif
/ Heres one for you... #34
this is true Mike...same as oxygen is medical and industral grade also....gee do you really thik one of these guys would try and breathe n/ox ????I sure hope not...lol..Sid
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2017 Ford F-150...
Metal Peacock Lawn Art Statue (A66738)
Metal Peacock Lawn...
CAT 988B Final Drive (A68134)
CAT 988B Final...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
