3-Point Hitch Help,,
   / Help,, #1
Jonny3
UK
Ferguson TE20
Hi,
I'm currently looking after my employers estate and using his Massey TE20 tractor to pull a trailer. The problem I have is that I cannot lower the tow bar to hook up the trailer. I can't remember how I was shown to lower it.
Mad I know but can anyone help??
Cheers. John :)
   / Help,, #2
:welcome:
From Alabama. Someone here should be able to help but it may take a few days being the holidays and all.
   / Help,, #3
When you are sitting on the tractor,look to right side, do you see a half moon looking thing with nob,slide that thing down that will drop your three point.It has been many years since i had mine but i think i have that right.If this doesnt fix your problem send pictures.
   / Help,,
:welcome:
Thank you! :thumbsup:
   / Help,,
Hi Ron.
Yep the half moon handle is there and when I slide it down the three point doesn't go down??
:smiley_aafz:
   / Help,, #9
I take a try and guess that you have a T-boom between linkage and top link with 2 struts down to drawbar? If tractor is not converted at one time then it is the original solution. On T-boom should be a button to be pressed or a lever to twist / lift depending on the style T-boom you have.
   / Help,,
Thank you for your suggestions. Yes it has a T-boom, which is in the middle of the 2 struts. I've pulled it and twisted it but nothing budges!
New Holland C345 (A50120)
New Holland C345...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
UNUSED FUTURE EXCAVATOR RIPPER (A51244)
UNUSED FUTURE...
